Ok reloaded and re-exported all the FP from tour 2 again Igor. All work in a variety of Flight planners ie: Plan G, VFR Flight, Little Navmap as well as my sim without issue. Hopefully will work in your sim. Seems this issue is only related to the odd FSX/FSX-SE installs for some reason.
Anyways new FP attached here.
PS: I use winrar 5.60 (64-bit) (latest version) to compress files to zip or rar format. Please check your extraction program just in case it is an older version and not extracting files correctly or completely. Not sure but maybe down the latest version of winrar or winzip.
One other thing, try to load a FP up in your planner if you use: IE Plan G, Little navmap, VFRFlight and try to export to a FSX FP from your PC and see if that works in your sim. (My OS is Windows 10 64bit).
