Author Topic: SIRP Texture problem at PAPG  (Read 3398 times)
Buschpilot
Re: SIRP Texture problem at PAPG
« Reply #15 on: June 18, 2018, 03:11:29 PM »
Yes, the SIRP Update 2.3 has been online for three days.
Did you use the configurator and put on P3Dv4 +?
And does the problem of black buildings still exist?
Are there any black buildings in the camps?
Best regards
Mike
BBQSteve
« Reply #16 on: June 18, 2018, 03:54:47 PM »
Used configurator, set to v4
Black buildings still exist
Have not been to camps.
BBQSteve
« Reply #17 on: June 18, 2018, 04:22:06 PM »
Screen shot of new screen shot
http://prntscr.com/jwg8cu
Buschpilot
« Reply #18 on: June 18, 2018, 04:33:10 PM »
Please check the camp's (SRC 2/3/4/8) for black objects.
Exist on your PC the following files?
- SIRP_ lens_ez_oil_drums.bgl
- SIRP_Buildings_LIB.bgl
- SIRP_Misc_LIB.bgl
These are from the first SIRP publication and must be deleted / disabled.
Duplicate objects often generate such errors (black objects).
Only the following files may exist and be active!
For FSX / P3D setting in the configurator:
- 00_FSXP3D_lens_ez_oil_drums_LIB.bgl
- 00_FSXP3D_SIRP_Buildings_LIB.bgl
- 00_FSXP3D_SIRP_Misc_LIB.bgl
For P3Dv4 + setting in the configurator:
- 00_P3D4_lens_ez_oil_drums_LIB.bgl
- 00_P3D4_SIRP_Buildings_LIB.bgl
- 00_P3D4_SIRP_Misc_LIB.bgl
Which files are active with you?
Best regards
Mike
BBQSteve
« Reply #19 on: June 18, 2018, 05:59:55 PM »
SRC2 -  Black center building with snow on top.
SRC3 - Black shed.
SRC4 - Black building with large snow mound floating over it and looks like an elevation problem here.
SRC8 - Black depot, but fireplace chimney fine. Again looks like elevation problem as large snow mound elevated airport sunken.
- SIRP_ lens_ez_oil_drums.bgl - NO
- SIRP_Buildings_LIB.bgl - NO
- SIRP_Misc_LIB.bgl - NO
- 00_FSXP3D_lens_ez_oil_drums_LIB.bgl - YES OFF 00_P3D4_LENS_EZ_OIL_DRUMS_LIB.BGL ON
- 00_FSXP3D_SIRP_Buildings_LIB.bgl YES OFF P3D4 ON
- 00_FSXP3D_SIRP_Misc_LIB.bgl YES OFF P3D4 ON
- 00_P3D4_lens_ez_oil_drums_LIB.bgl - ON
- 00_P3D4_SIRP_Buildings_LIB.bgl - ON
- 00_P3D4_SIRP_Misc_LIB.bgl - ON
Thanks for your help!
Buschpilot
« Reply #20 on: June 18, 2018, 11:44:16 PM »
Since which version do you use SIRP?
And since which version do you have the problems with the black buildings?
Please use the configurator to activate the FSX / P3D objects.
Is the problem still there then?
Best regards
Mike
« Reply #21 on: June 19, 2018, 07:01:11 AM »
What are you seeing in the scenery object tester?
BBQSteve
« Reply #22 on: June 19, 2018, 11:10:10 AM »
?????  All of these questions have been previously answered.
I am using 2.3 of SIRP, have used all previous versions with same problem.
Will try fsx/p3d option.
Scenery object tester shows all objects and all textures there. No black objects.
BBQSteve
« Reply #23 on: June 19, 2018, 12:36:03 PM »
No difference when switched to fsx/p3d.
Buschpilot
« Reply #24 on: June 19, 2018, 02:04:39 PM »
Okay...
Then set please again with the configurator on P3Dv4 + and then disable the 00_P3D4_SIRP_Buildings_LIB.bgl...
Just attach to bgl still .xxx ...
What about the SIRP base (PAPG)?
Still black buildings or are the buildings missing now?
Best regards
Mike
BBQSteve
« Reply #25 on: June 19, 2018, 04:17:14 PM »
Unexpectedly, they are still there black. This means to me there must be another file, but I have searched my drive for duplicates.
Buschpilot
« Reply #26 on: June 19, 2018, 04:36:19 PM »
Yes you are right.
Now it is looking for the needle in a haystack (a German proverb).
Please disable all AddOns (except TongassFjordX).
Continue disabling all additional object libraries (including RTMM).
Now only the P3D standard sceneries, TongassFjordX and SIRP should be active.
Please leave the 00_P3D4_SIRP_Buildings_LIB.bgl deactivated.
As a result, a lot more objects are missing in the SIRP base ...
But it's only about the black buildings.
What does the result look like now?
Best regards
Mike
BBQSteve
« Reply #27 on: June 20, 2018, 10:13:48 AM »
No objects at this end of AP
Sorry, had another file turned off and didn't realize it. Buildings still black.
« Last Edit: June 20, 2018, 12:28:44 PM by BBQSteve »
Buschpilot
« Reply #28 on: June 20, 2018, 03:35:15 PM »
@BBQSteve
do I understand it right...
Except SIRP
-All AddOn sceneries (Pay and Freeware) turned off / disabled?
-All object libraries have been turned off / disabled?
As my recommendation in the previous post?
And the buildings are still black?
Best regards
Mike
BBQSteve
« Reply #29 on: June 20, 2018, 03:57:02 PM »
All RTMM scenery and libraries were turned off.
