MFC0001 completed on 06/28/18, Jim R MFC0019
MFC0002 completed on 06/29/18, Jim R MFC0019
I see all the legs flown Jim so will award the MFC0001 Misty Triangle and MFC0002 Misty Hub Excursion.
you flew the single legs. But for tour status and updates have to generate the tour legs from within the tours themselves via a bid for each leg.
To do Tour Flight bids:
1. Sign up on the tour - via Tour Center
2. On that tour, Select your next flight - The 1st leg will open for you.
3 Press "fly leg"
4. Log into Cigar Box and go to settings and remove the check mark on flight number. This enable direct bid loading).
5. Press the get data button and the correct flight as per your bid should load.
When your sim is ready start flight in Cigar Box. When done, file the pirep.
When you are ready to fly the next leg, go to the tour you are flying and the next leg will be open for you to fly (bid).
