Cannot for the life of me figure out how to add POI to this map system, anyone know how? Teecee.
Hi Teecee,
It's both simple and tricky to add a waypoint / POI in LN indeed. It's different from Plan-G, for instance, where you can edit waypoint coordinates directly in the program, while in LN you can change their names/titles only. Anyway...
I usually make a draft of my flight plan by adding intermediate waypoints as close to my "specific locations" as possible. Then I save the flightplan as a normal PLN file and manually edit the coordinates inside the file (I use Notepad++ to insert exact lat/lon coordinates).
Another method is to make a Google Earth KML file which contains your POIs/waypoints and import the resulting KML to LN for viewing (
File -> Add Google Earth KML...). Btw, Google Earth can import/open text-based Plan-G CSV files which you can find on Here2There page. So, after importing your CSV into Google Earth, just save it as a KML map and add it to LN interface as described above.
Yet another possible way
well-described here is to go to
Flight Plan -> New Flight Plan from Route Description, or by pressing
Ctrl+Shift+N, and enter waypoint coordinates individually based on
specific format.
Hope this helps!
