Author Topic: Inconnu Lodge in the Yukon  (Read 6654 times)
BBQSteve
Re: Inconnu Lodge in the Yukon
« Reply #15 on: February 08, 2018, 08:51:04 AM »
How do you select it manually, there is no option in the drop down except for 3 dock positions and r/w's?
« Reply #16 on: February 12, 2018, 11:41:36 AM »
In FSX
1. Click 'World'
2. Click 'Go to Airport'
3. Type either 'Inconnu Lodge] in 'By airport name'  or 'CAD2' in 'By airport ID'
4. In 'Choose runway starting position box' you have the following choices:
Active Runway
12
25 (water)
30
7 (water)
DOCK 1--GA
DOCK 2--GA
DOCK 3--GA
5. Choose either 12 or 30 for the dirt runway.
If your not using plain vanilla FSX I don't know what the drop down 'Choose runway starting position box' choices are.
« Last Edit: February 12, 2018, 11:44:59 AM by spud »
BBQSteve
« Reply #17 on: February 12, 2018, 12:21:57 PM »
P3DV4.2
« Reply #18 on: February 13, 2018, 10:50:29 PM »
P3DV4.2
Ah well there ya go, different animal it appears.
« Reply #19 on: February 14, 2018, 06:54:58 AM »
No worries Steve.. and not really to much different. The FSX method that Spud described is almost the  exact same in any and all of the sim versions: P3Dv1234x. Just in P3D the tab is referred to as "Navigation".
 So do the following to go there.
1. Before you can go to the location, ensure the scenery is installed in your sim first. Once done you can go to Inconnu Lodge (CAD2) with no problem and see all of the sites.
2. After scenery set up in your sim, Start your sim and load up any flight or create your own. CAD2 Inconnu will now be present an an airport in the sim's airport data base. Then when your sim is loaded up at any location for a flight, just go to the "Navigation tab" then select "Go to Airport:
3. Enter the Inconnu or just CAD2 as the ICAO,
If you want to Choose your starting position:
Active Runway
12
25 (water)
30
7 (water)
DOCK 1--GA
DOCK 2--GA
DOCK 3--GA
Tower View
If you don't choose any specific starting location the sim will place you on the active. (In this case water!!) so put on your float/or amphibian first)
Click OK and your sim will you at Inconnu Lodge ICAO (CAD2).. voila the sim will move you over to CAD2. (See pic attached)
Now if you create a flight plan to start at CAD2, then you can just load it up and your sim will start you there.
« Last Edit: February 14, 2018, 07:02:33 AM by nbrich1 »
« Reply #20 on: February 14, 2018, 08:57:28 AM »
I remember discovering the active runway box was actually a drop down. I flew for a long time without knowing that. :-\
BBQSteve
« Reply #21 on: February 14, 2018, 02:07:54 PM »
I think that has been there since '98.
« Reply #22 on: February 14, 2018, 03:50:56 PM »
I been "there" since '98 too ... but totally missed that for years.  Was talking to Holger one time asking why he didn't start a plane at the dock, always out in the water. He said I need to ask it to start at the dock ... "huh?" THEN THE LIGHT WENT ON ...  can't believe I had missed that one for a long time.
« Reply #23 on: February 14, 2018, 07:20:04 PM »
Kinda like the secret clik spot for the dancing girls!  :o ::) ;D
