Author Topic: Cliffs at AP's Tsongas Fjords P3Dv4.1  (Read 2685 times)
harlank23
« on: January 20, 2018, 04:42:37 PM »
Hi Folks
       I have added a few jpg of the terrain issues I am having in Tsongas Fjords.  Everything but these major airports seem to be working fine.  I followed guide for installing into P3dv4.  Anyone have this problem, or have any ideas?  Any help greatly appreciated.
                                               harlank :'(
Re: Cliffs at AP's Tsongas Fjords P3Dv4.1
« Reply #1 on: January 20, 2018, 05:19:06 PM »
Try setting your mesh resolution to 5m.
harlank23
« Reply #2 on: January 20, 2018, 07:03:10 PM »
Thank you for your reply and idea.  Unfortunately, no change.  My sliders,  for the most part, are all the way to the right.
                               harlank
« Reply #3 on: January 21, 2018, 04:09:12 AM »
Did you forget to import the 8 Tongass elevation adjustment files into \scenery\world\scenery?
« Reply #4 on: January 21, 2018, 07:20:31 AM »
Hi good day
 look at your scenery .cfg and number area layers .
or cut / past on your desktop and run your sim again and wait to rebuilding all area . look if it solve your elevation .
You can do also for Terrain.cfg
they are in ProgramData / LM/ P3D .
and look at your root folder P3D if they are in it ? may the 2 folders can be here delete it or cut/ past on your desktop ..
befor run your P3Dv4
Good sunday
harlank23
« Reply #5 on: January 21, 2018, 03:08:25 PM »
Thanks, Guys, for all your help.
       I figured it out.  Not thinking that maybe Tongass Fjords had its own terrain mesh,  I was using Toposim Alaska.  As soon as I deactivated the Toposim mesh everything looks good(Tongass must have its own mesh because the mountains are definitely not default!).  If I fly out of the Tongass Fjords/Orbx regions the terrain wouldnt look so good without mesh, but until Orbx does more areas of Alaska why would I want to?   Thanks again all.
                                    harlank
