Author Topic: No hangers or buildings at Mistys place, or anywhere else.  (Read 3013 times)
Zeroready
« on: December 20, 2017, 03:49:54 PM »
Hi all I'm sorry I'm new. I have FSXSE, Orbx PNW and PFJ. I have all the RTMM libraries, activated scenery. But there are only a few ground objects at mistys place, no hangers or anything. At Owikeno Lake the BBQ building aren't there, just campfires and tents, some floatplanes in the water. I feel like I must be missing something.
The readme for mistys place says "1. You can go locate and then download and install the following file to make sure all objects in my other scenery areas are visible in FSX. The file name is: ez_1.zip
I located this file at Flightsim.com at this link: http://www.flightsim.com/kdl.php?fid=145677 " but it's not there. Do i already have the ez_1 stuff if i have the rtmm libraries and the ahzx library?
Re: No hangers or buildings at Mistys place, or anywhere else.
« Reply #1 on: December 20, 2017, 05:42:13 PM »
Welcome Zeroready,
Make sure you have downloaded and installed ALL of the RTMM libraries. When you have done this, download and install the RTMM Object Checker, http://www.return.mistymoorings.com/object_libraries_build/
The ez_1 library is already incorporated into our RTMM libraries and you won't need it from another source. If you already have it you need to uninstall it or you will experience problems.
If you continue to have problems then post screenshots along with the coordinates of the problem areas. We'll help you get things sorted out. Just ask!
