Author Topic: Tongass Fjords X terrain problem  (Read 2782 times)
marc2140
« on: December 20, 2017, 12:15:39 PM »
I used to have TFX installed at my FSX. I recently switched to FSX-SE. I now seem to have the terrain problems I read a lot about: all water is covered by trees, airports like CAB5 have no runway anymore, etc.
I can see tutorials for people installing TFX in P3D, but not for a switch to FSX-SE. Can anyone help me?
Thx.
Marcel
Re: Tongass Fjords X terrain problem
« Reply #1 on: December 20, 2017, 07:52:37 PM »
Hi look at your entries FSX : scenery .cfg ..
you need 40 entries TONGASS FJORD with the good numbers layers
that all
« Reply #2 on: December 20, 2017, 08:14:31 PM »
Hi Marcel,
     What Patrick is saying is to be sure your TFX entries are in your FSX-SE Terrain.cfg file.  Follow the procedures for adding the entries to the terrain.cfg and renumbering it.  (or at least make sure the entries are in there.)  Also, make sure your TFX scenery.cfg entries of "Higher and Lower priority" are added and placed below the FTX entries.  Then it should work.  Viola!   8)
« Reply #3 on: December 21, 2017, 05:15:45 AM »
AS Jeff said
Voila !  ;)
marc2140
« Reply #4 on: December 21, 2017, 08:51:12 AM »
The 40 terrain entries + renumbering were not enough. The whole installation had gone to my old FSX directory.
But I managed to move the simobjects, effects, sounds, Altitude corrections to the FSX-SE spots, and hopefully everything is working now. The trees have disappeared, but still need some extensive exploring of the area + add the RTMM addons.
Thanks for yr help guys.
Cheers.
Marcel
