Author Topic: Misty Moorings Taxi Office  (Read 4066 times)
scanham
« on: December 15, 2017, 09:06:50 AM »
Hey Guys,
The Halibut Cove Trip Tic reads:
TO:   Halibut Cove, AK (PFXX)
We start off at the Misty Moorings Taxi Office at the Wasilla Airport. Using the FSX MAP feature, set your aircraft at:
Latitude: N61 34.38
Longitude: W149 33.04
Heading: 288
Altitude: 0
Speed: 0
I have installed the Taxi Office but couldn't find it at the Wasilla Airport (PAWS).  I went to the map and relocated using the coordinates above and end up in the middle of the woods.
I must be doing something wrong.
By the way, I went ahead and flew the trip tic anyway and I just want to say the your Halibut Cove is spectacular!  I don't want to leave!.
Thanks,
Steve Canham
MFC0077
Re: Misty Moorings Taxi Office
« Reply #1 on: December 15, 2017, 10:40:09 AM »
Shows for me. Make sure that you have everything installed correctly and that your scenery order is correct. Post back if you still can't get it to work.
« Reply #2 on: December 15, 2017, 02:29:35 PM »
The Misty Office there comes from the Misty Air Taxi scenery. So you need to install that and it will be there. We use that one for a lot of Trip Tix out of that area. There's another one that is equally as long and interesting up to "The Last Resort".
« Reply #3 on: December 15, 2017, 03:21:44 PM »
He said he installed the Taxi Office, which I took to mean Misty's Air Taxi, but maybe I misread what he meant. I'm thinking that if all he sees is the middle of the woods then there's another problem.
« Reply #4 on: December 15, 2017, 04:31:20 PM »
Geez, good point! Woods???  Yep, something wrong there.
« Reply #5 on: December 15, 2017, 08:17:53 PM »
Hi Steve,
The coordinates are a little off.  Try these ones.
Latitude: N61 34.28
Longitude: W149 33.07
Heading: 211
Altitude: 363
Speed: 0
« Last Edit: December 15, 2017, 08:59:49 PM by jeff3163 »
« Reply #6 on: December 15, 2017, 09:32:49 PM »
Is that "off" in the ticket, Jeff?
« Reply #7 on: December 15, 2017, 09:51:18 PM »
Yes, and I quote:
Route Overview
Latitude: N61 34.38
Heading: 288
Altitude: 0
Speed: 0
This places you in front of the Misty Moorings Air Taxi Service building at the Wasilla Airport.  ...  ;)
(the typos are common, hit 4 instead of 7, 3 instead of 2, etc. )
« Last Edit: December 15, 2017, 09:55:37 PM by jeff3163 »
« Reply #8 on: December 15, 2017, 09:53:38 PM »
Rats, I’ll go after that.
« Reply #9 on: December 15, 2017, 10:00:09 PM »
« Reply #10 on: December 15, 2017, 10:20:55 PM »
OK, the Trip Ticket is fixed. i used the coordinates I have for the Misty Moorings Taxi scenario. I always put the altitude at "0" even though it may be 3000 feet ... what that does it puts you ON THE GROUND, and not a foot or two (or more) above it if your barometer isn't set yet. A "0" always puts you on the ground regardless of the altitude.
So it should be OK now. Thank you Jeff!
scanham
« Reply #11 on: December 16, 2017, 09:06:43 AM »
Thanks guys. Looks better. ;)
Steve Canham
MFC0077
« Reply #12 on: December 16, 2017, 09:43:57 AM »
Thank you for catching that, so we could fix it.  8)  Better now.   :)
« Reply #13 on: December 16, 2017, 10:10:04 AM »
YES! Thank you for catching it!  We really appreciate finding those things and making everything work. There's a lot to keep track of, so the more eyes on it the better! THANK YOU!
