Author Topic: Placement  (Read 809 times)
xxd09
Placement
« on: October 26, 2017, 03:25:38 PM »
Hi All
Just a small but annoying point
In P3Dv4.1 every time I load a new airport -Orbyx or from another designer my 10 RTMM libraries move back to the bottom of the last Orbyx scenery areas that I have-in my case ORBYX!OPENLC_NAMERICA2
I then have to move them back to above OrbyxLibs
Any cure for this?
xxd09
Re: Placement
« Reply #1 on: October 26, 2017, 06:00:50 PM »
Use the FTX Central program to set your insertion points.  Example attached.  If you have OZx and Tongass Fjords X software.
Click to enlarge
  • Troubleshooting
Re: Placement
« Reply #2 on: October 26, 2017, 07:45:00 PM »
Spud, I am up to version 3.2.3.0 of FTX Central.  You're showing v3.2.1.1 there. ;)
xxd09,
     Choose the lowest RTMM library and use that for the FTX insertion point, if you don't have OZx.  All FTX will load in below that.  Then choose TFX as the insertion point for OLC, and it will always load below TFX, which is below all FTX, right.  That keeps it all sorted.   8)
« Last Edit: October 26, 2017, 07:49:23 PM by jeff3163 »
Re: Placement
« Reply #3 on: October 27, 2017, 12:54:15 AM »
 3.2.3 is only available if you have opted into the fastlane beta program.
https://orbxsystems.com/forum/topic/139402-objectflow-2-open-beta/
Re: Placement
« Reply #4 on: October 27, 2017, 02:05:21 PM »
Correct Sue,
Due to the fact that I'm having to rebuild my entire HD/FSX installation and I'm tired of being a BETA tester and did not opt into Objectflow 2.  >:(
xxd09
Re: Placement
« Reply #5 on: October 27, 2017, 07:10:17 PM »
Hi jef3163
Thanks for that-all working now
xxd09
