Author Topic: Missing Lake (Avoss Lake USFS Cabin)  (Read 1079 times)
« on: October 23, 2017, 04:54:58 PM »
Flying to the Avoss Lake USFS cabin, a little surprise ... no lake.  It also didn't not show up on the GPS map either. Not sure what the problem might be with this one. Settings at 5 meters and 7 cm. Using Global Vector and NA Landclass with Pilots Mesh.
  • RTMM Library Manager
Re: Missing Lake (Avoss Lake USFS Cabin)
« Reply #1 on: October 23, 2017, 05:18:24 PM »
Here's what I see at the same location. Only difference is I'm using FSXDX10 and no Pilot's Mesh.
« Reply #2 on: October 23, 2017, 06:35:39 PM »
Just for fun, I unchecked Pilots Mesh ... got the same result. So it must be something else.
Thanks for that pic and post!
« Reply #3 on: October 23, 2017, 07:16:44 PM »
I started removing things ... the ORBXOPENLC group (NA1, NA2, Europe, etc) was causing the problem. When I unchecked these. The lake returned.
dbutterf
« Reply #4 on: October 23, 2017, 08:16:35 PM »
Doug,
Do not think it's OrbX products. I have NA and Alaska, this is what I see.
Dayle
« Reply #5 on: October 23, 2017, 08:30:08 PM »
Hi Dale .. all I know is I 'unchecked' them and I'm seeing the lake.  So maybe it is interfering with something else? Beats me.  Just flew back from Avoss Lake to Sitka, everything looking OK, who knows what the elves are doing in our computers while we sleep?? :-)  Thank you for the pic and the comment ... curiouser and curiouser.
  • Troubleshooting
« Reply #6 on: October 23, 2017, 08:47:13 PM »
Sitting at Avoss Lake cabin.  ;)
« Last Edit: October 23, 2017, 08:52:29 PM by jeff3163 »
« Reply #7 on: October 23, 2017, 08:56:00 PM »
It has to be "where" I have things in my scenery library.  When I uncheck the ORBXOPENLC folders, it works fine.
The "pink" shows they are "unchecked". I've got them right below the FTX stuff. then the OLC stuff below. Is your's that way Jeff?  This configuration gives me the lake fine. Everything else looks OK too, but ORBXOPENLC folders are "off."
  • Troubleshooting
« Reply #8 on: October 23, 2017, 09:04:50 PM »
Here is what mine looks like. (or what you can see of it anyway.)  :P  N and S America near bottom.
« Reply #9 on: October 23, 2017, 09:09:36 PM »
Interesting, your ORBX!OPENLC files are below Tongass Fjords. Do you have OLC-NA_Lights, OLC_NA1, OLC_NA2 and OLC_SA1? If so where are those?
  • Troubleshooting
« Reply #10 on: October 23, 2017, 09:15:06 PM »
I don't have ANY named OLC anything!  What is that? ???  Only ORBX!OPENLC_???? in mine.   :-\
Yes, my Tongass Fjords is the "insertion point" for the OpenLC files, as specified in FTX Central 3.
« Last Edit: October 23, 2017, 09:17:01 PM by jeff3163 »
« Reply #11 on: October 23, 2017, 09:16:25 PM »
Darned if I know what they are.  I'll take them out and turn on ORBXOPENLC again and see what happens.
Update:  OK, I took those OLC one out. I put the ORBX!OPENLC folders below Tongass X ... everything looks good.
« Last Edit: October 23, 2017, 09:23:07 PM by Doug »
  • Troubleshooting
« Reply #12 on: October 23, 2017, 09:29:21 PM »
It appears that the OLC files may be a result of a "manual install".  The folder names are OLC, but Orbx names the entry ORBX!OPENLC when it installs it.  If you do it manually, the result would be files named as yours were.  So you had doubled the install of Open LC.  Does that sound close?
« Reply #13 on: October 23, 2017, 09:33:31 PM »
It makes as much sense as anything! :-)   Flying back to Sitka now, everything looks beautiful. Must have been those files screwing me up. Thanks Jeff (and the other folks too!)
  • Troubleshooting
« Reply #14 on: October 23, 2017, 09:37:44 PM »
Happy Flying!  8)
