Author Topic: aspen flats cabin  (Read 2876 times)
Lipra
aspen flats cabin
« on: October 15, 2017, 07:25:44 AM »
I have just done a flight from PAWD Seward and find no cabin at the end. Looking at the missing cabins folder there is no entry for this cabin. any advice would be appreciated
Re: aspen flats cabin
« Reply #1 on: October 15, 2017, 08:42:09 AM »
Hi Lipra,
     I see the cabin on my system, right where it is marked on the map.  Exactly!  Green arrow points to it.  ;)
« Last Edit: October 15, 2017, 09:11:14 AM by jeff3163 »
« Reply #2 on: October 15, 2017, 02:07:18 PM »
he may have used a cabin object from a non-RTMM library.  Unless you had that lib. it would not show.
« Reply #3 on: October 15, 2017, 08:07:45 PM »
Hi ...
Yes it is there. Standard object.  It is just very difficult to see .. it's a BIG world out there!
« Reply #4 on: October 15, 2017, 08:31:08 PM »
Hi Lipra,
     Could you go out to the coordinates displayed in my pics and take a screenshot or two of the area.  A picture really helps when investigating a problem.  Look for the smoke plume, if it is there.  Otherwise, just snap a pic of the valley floor where the cabin should be sitting.  I "assume" you have the latest version of the missing cabins installed? ???   Thanks.  :)
LAT:  N60 22.23"
LON: W149 58.43"
Alt:   745
Mag: 107
 8) :) 8)
« Last Edit: October 15, 2017, 08:45:10 PM by jeff3163 »
Lipra
« Reply #5 on: October 16, 2017, 05:28:01 AM »
Thanks guys I have put the co-ordinates in again and demolished the cabin so no need to go there now.
 I can only think that I transposed part of them when I checkd. It is well hidden and I suspect I flew all around it.
« Reply #6 on: October 16, 2017, 07:23:20 AM »
So ... this means that you do have the cabin?  (or you did until you demolished it?)  I think you're saying you have the cabin, and all is right with the world.  Cool!   8)
Lipra
« Reply #7 on: October 18, 2017, 11:08:47 AM »
correct on both count Jeff >:(
