Author Topic: Installing Victoria+ in P3Dv4  (Read 12035 times)
Re: Installing Victoria+ in P3Dv4
« Reply #15 on: October 21, 2017, 01:57:21 PM »
IE:Victoria +
there are some AI problems in FSX as the AI are old FS9 version.  I had a program that would convert those files to FSX compatible but lost it when HD failed.
I think it came from a developer with "Duck" in the name be CRS has set in (CRS=Can't Remmember S##t)
UPDATE
Scruffyduck it is.
http://www.scruffyduck.org/home/4584106797
« Last Edit: October 21, 2017, 02:00:26 PM by spud »
« Reply #16 on: October 21, 2017, 02:00:20 PM »
I had installed Victoria Plus into P3DV4 and had no issues.  After I upgraded to P3DV4.1, client and content, I had land where water should be around CYCD.  After I removed Victoria Plus everything when back to normal.  Anyone have this issue?  If so, were you able to fix it other than by removing Victoria Plus?
Danny
Hi Danny,
     I've just upgraded my sim to 4.1 and encountered your issue.  I avoided "removing Vic+" and instead shuffled it around in my Scenery library.  After placing it below the FTX entries (above the TFX entries), it looks normal again.  ;)   Try that.   :-\ ??? ;) :o 8)
Patrick,
     Placing it above FTX causes the land where water should be issue, at least for me.  That is where it was to start with.  ;)
« Last Edit: October 21, 2017, 03:20:08 PM by jeff3163 »
« Reply #17 on: October 21, 2017, 03:25:01 PM »
My victoria8 + is instaled on V4.1
and also the LR 2017 and CYYJ scenery
And the addon works fines
« Reply #18 on: October 21, 2017, 03:33:34 PM »
That's beautiful, Patrick!   8)   :)
« Reply #19 on: October 21, 2017, 03:39:40 PM »
Thanks Jeff
and the Cessna Caravan FSX also V4.1 in screen & for the screen
That is cool
Good week End guys
RCFlyer
« Reply #20 on: October 22, 2017, 09:47:44 AM »
Jeff, thanks.  I tried putting Vic Plus below the FTX entries.  That did allow the water areas to display correctly, but, the Vic Plus airports did not display correctly (some missing buildings, etc.).  I haven't given up yet.
Danny
« Last Edit: October 22, 2017, 01:06:19 PM by RCFlyer »
« Reply #21 on: October 24, 2017, 07:30:11 AM »
Hi RC flyer
Did you installe the scenery as methode TONGASS Fjord install ?
said me where with coordinates you have prob ! (screen shoot)
RCFlyer
« Reply #22 on: October 24, 2017, 05:33:06 PM »
Patrick:
Yes, I installed using the same method as Tongass Fjords.  The area where I had the issue was just west of CYCD.  Approximate coordinates are: 49.092434, -123.702448
Danny
« Reply #23 on: October 25, 2017, 06:09:51 AM »
Patrick:
Danny
Hi Danny
i convert your coordinates
49° 05' 57" N
123° 42' 03 75" W
and i'm at East of CYCD in water ?
i take some screen here you have coordonate in left corner
RCFlyer
« Reply #24 on: October 25, 2017, 11:00:07 AM »
Oops,,,I appear to be directional challenged.  Sorry.  You are in the correct spot.  The last picture, where there is water I get land with Vic Plus install.
Danny
« Reply #25 on: October 25, 2017, 11:48:21 AM »
Hi Danny,
Just checking....you are using Vic+ for PNW v8, right?
RCFlyer
« Reply #26 on: October 26, 2017, 10:08:49 AM »
Well crap.  I just checked and it is Version 7.  Headed for the store......
Danny
RCFlyer
« Reply #27 on: October 26, 2017, 12:49:15 PM »
Installed Version 8 and it works with no problems.  Funny how that worked......
Thanks guys.
Danny
« Reply #28 on: October 26, 2017, 01:57:50 PM »
Glad you got it sorted!
« Reply #29 on: October 26, 2017, 09:07:06 PM »
I said in my first post Victoria 8 +
That last version 7 + 1= 8   ;D
glade you find the correct install RCFlyer
witing for some screen
