Author Topic: Librairies ORBX How to regenerate  (Read 383 times)
« on: September 11, 2017, 07:22:43 AM »
Hi a tweak very simple for generating LIB ORBX because sometime you see à bug in scenery .
simply go to your Root Folder P3Dvxx/ ORBX/UserDocuments/Versions/FTX_AA_ORBXLIBS.TXT /
Open with notpad delete the text and register .
Open your FTX central 3.2.2.8 and check for install Lib ORBX , it's very quick install !
that all !
Done
Re: Librairies ORBX How to regenerate
« Reply #1 on: September 11, 2017, 02:03:00 PM »
Patrick,
you can simply delete the textfile. There's no need for any editing the file or delete contents inside the file.
After deleting the textfile, open ftx central and you get notified there's an update for the libraries avaible you should update.
After the update is completed ftx central will generate a new ftx_aa_orbxlibs.txt textfile.
Regards from Munich, Germany
P3Dv4.2,FlyInsideP3d4,OpusFSI,REXSkyForce3D
i76700K 4Ghz;16GB RAM;Asus 2xGTX1080SLI;SSD:Evo850 256GB Win10Pro64;Evo850 512GB P3D;HDD:1TB;27" Monitor;HTC Vive HMD;HOTAS Warthog;X52;VBS ProAT Pedals;F1GTN750/650
« Reply #2 on: September 12, 2017, 07:29:45 AM »
Hi Corbu Good day
Yes it is   ;)
