Author Topic: Bush Hawk X - Payload Manager Fix?  (Read 2570 times)
bt103504
« on: August 25, 2017, 08:12:34 AM »
Greetings All! I've managed to install the epic Bushawk into P3dV4 without issue and it flies and works beautifully. I was curious if anyone has figured out a solution to getting the payload manager to work for this aircraft. This is the window where you can control the visible payload, gas consumption, and passengers.
Thanks!
« Last Edit: August 25, 2017, 08:10:52 PM by bt103504 »
Re: Bush Hawk X - Payload Manager Fix?
« Reply #1 on: August 25, 2017, 04:58:24 PM »
Hi bt103504,
     Are you talking about the Aerosoft BeaverX or the Bushhawk?  I do own the bushhawk, but haven't checked it in v4 yet.
bt103504
« Reply #2 on: August 25, 2017, 08:12:18 PM »
Hi Jeff. I'm so sorry for the confusion I'm talking about the Bushawk. I've used the Estonia migration tool to get the bushawk into P3dV4 and it worked beautifully. However the only problem is that the payload manager doesn't work. I'm not sure if perhaps there's a .dll entry missing that perhaps I'm unaware of or what?
