Home (FSX/P3D)
Home (MSFS2020)
Scenery
Navigation
Enhancements
Activities
Welcome,
Guest
. Please
login
or
register
April 25, 2024, 11:32:21 AM
Home
Help
Login
Register
Misty Moorings Forums
Prepar3D-Version 4
P3D v4 CTD in Tongass Fjords X
« previous
next »
Print
Pages:
1
2
3
Author
Topic: P3D v4 CTD in Tongass Fjords X (Read 13754 times)
Misty Moorings Site Admin
Hero Member
Re: P3D v4 CTD in Tongass Fjords X
Reply #30 on:
November 30, 2017, 08:07:32 AM »
Trees in the water? Go to Step Table #5 on the Installation/Getting Start Page ... that is the area that discusses installing Tongass X. There are two things there that could help you. Notice the "trees in the water" problem ... you can go to our FAQ page and see pictures of Wrangel and compare to what you've got.
There is a fix for this on the faq page, but Poppet has also discussed the fix in her "Installing Tongass Fjords X into Prepar3D V3 and V4". In the top section it is discussed.
Let us know if this helps.
Last Edit: November 30, 2017, 08:16:38 AM by Doug
Logged
DocScott
Jr. Member
Reply #31 on:
November 30, 2017, 09:40:58 AM »
Hi !
Thanks for the quick answer.But I meant,when I am seeing the sea,where it should be,
that is no proof for Tongass Fjords to be installed.Can I go to a special place,that would proof that TF is installed?
Scott
Logged
I am dreaming of a visit to Alaska in winter time.
Staying with friends and enjoying nature.
Misty Moorings Team
Member
Reply #32 on:
November 30, 2017, 06:42:34 PM »
Go to Sitka and have a look...
Last Edit: December 01, 2017, 11:39:23 AM by dexthom
Logged
Hero Member
Reply #33 on:
November 30, 2017, 06:50:15 PM »
Send us a picture of something YOU have that is unique. We'll grab a screen shot of the same place (if you give us lat/long) and you can compare.
Logged
Misty Moorings Team
Hero Member
Watercraft-Panels-Paint
Reply #34 on:
November 30, 2017, 08:08:54 PM »
Hi DocScott,
Yes, go to Sitka and take a look at the airport area, and the marina behind it. Look for AI cruise ships in the open water area southwest of PASI. There will be AI TFX aircraft flying around too, if you've got them turned on. Take some screenshots of the area and post em here. If you've got the TFX Higher and lower elements in your scenery config (below FTX), you are most likely seeing TFX correctly in your sim.
Logged
Win10Pro64, MSFS 1.25.9.0, P3Dv4.3.29.25520, AMD Ryzen7 1800X@3.6 GHz , 32Gb RAM, GTX 1080 Ti, 2x42" Vizio Monitors, HTC Vive VR HMD, Saitek Yoke/Pedals/trim wheel, XBox360 Controller, G27 steering wheel w/shifter+pedals.
DocScott
Jr. Member
Reply #35 on:
December 01, 2017, 10:48:09 AM »
Thanks guys!
Here are three shots from Sitka
Should be alright,or?
Scott
Logged
rgerdes
Member
Reply #36 on:
December 01, 2017, 12:19:38 PM »
Looks correct to me...
Bob
Logged
Misty Moorings Team
Hero Member
Reply #37 on:
December 01, 2017, 01:57:54 PM »
Quote from: rgerdes on December 01, 2017, 12:19:38 PM
Bob
Yep!
Logged
Doc_Z
Jr. Member
Reply #38 on:
December 03, 2017, 01:02:40 PM »
I was looking at my terrain.cfg and noticed that the 40Tongass entries are qbove the ORBX entries. In Elaine's installation procedure, she has the 40 entries put at the end of the terrain.cfg file. Is my terrain.cfg file OK with the ORBX entries below the Tongass entries?
Logged
Misty Moorings Team
Hero Member
Reply #39 on:
December 03, 2017, 01:19:48 PM »
ORBX recommends that Tongass Fjords X be placed
below
ORBX/FTX entries for FSX. Chart from the ORBX guide.
Logged
Misty Moorings Team
Hero Member
Reply #40 on:
December 03, 2017, 01:38:13 PM »
He's referring to the terrain.cfg edit, Spud. They go at the bottom, and renumbered accordingly.
Logged
Doc_Z
Jr. Member
Reply #41 on:
December 03, 2017, 02:28:30 PM »
I don't see any problems with the way things look in the sim, but maybe I should re-arrange the terrain.cfg.
Spud, I have the scenery library in correct order, i.e. Tongass below ORBX/FTX.
Logged
Misty Moorings Team
Hero Member
Reply #42 on:
December 03, 2017, 04:18:03 PM »
I don't think it matters where in the terrain.cfg the TFX entries are, as long as the number sequence and final tally are correct.
"If it ain't broke ..."
Logged
Doc_Z
Jr. Member
Reply #43 on:
December 03, 2017, 05:39:11 PM »
Numbers are fine.
Logged
Misty Moorings Team
Hero Member
Reply #44 on:
December 03, 2017, 10:17:27 PM »
Jeff is correct.
Logged
Print
Pages:
1
2
3
« previous
next »
Prepar3D-Version 4
