Author Topic: Voo's heat shimmer  (Read 4940 times)
LouP
Voo's heat shimmer
« on: August 12, 2017, 09:27:14 PM »
I posted this in Hovercontrol but thought I would ask here, also.  I installed Voo's heat shimmer into P3D v4 for my choppers and it seems to function ok but the shimmer is much less transparent in p3d and almost looks like smoke.  I see in the effect file that it utilizes is the texture fx_wake_2.bmp.  Anyone know if there is a way to adjust the effect so that it is more transparent?
Thanks,
LouP
LouP
Re: Voo's heat shimmer
« Reply #1 on: August 14, 2017, 09:43:54 PM »
I figured this out myself.  I simply went into the effect file and changed the transparency setting under the color start attribute in both sections of the particle attributes and made it 2 instead of 4.  It looks good but I might reduce it further reduce it to 1 and see how that looks.
LouP
« Reply #2 on: August 14, 2017, 09:53:48 PM »
Good to know.  Glad you got it sorted out.  Good info.   8)  Thanks for posting what you did.  ;)
« Reply #3 on: August 15, 2017, 05:14:04 AM »
Hello LouP,
I don't know this heatshimmer file. What does it do when installed?
lionwing
  • Live and let live...
    • Airwego VA
« Reply #4 on: August 15, 2017, 06:33:36 AM »
I don't want to steer this thread elsewhere but I have tired to register at Hovercontrol several times without success.
« Reply #5 on: August 15, 2017, 08:10:07 AM »
Realize that this is also going to affect the way your other wakes (for ships) look.
LouP
« Reply #6 on: August 15, 2017, 02:17:19 PM »
It shouldn't as the change was used in the effect file itself, not the wake_2.bmp.
LouP
LouP
« Reply #7 on: August 15, 2017, 02:19:17 PM »
Hello LouP,
It adds the shimmer you see coming from the back of a turbine that is created by the heat of the exhaust.  I installed it in all of my helis and tied it to the beacon light as that should always on while the engine is running.
LouP
« Reply #8 on: August 15, 2017, 02:33:48 PM »
O.k., thank you for the information..
« Reply #9 on: August 15, 2017, 04:16:36 PM »
I realize that you changed the effect itself and not the bmp texture. That's why you should check to see if it changes ship wakes too. It probably will.
LouP
« Reply #10 on: August 16, 2017, 04:56:17 PM »
I don't understand, It is a completely different effect file from what the ships are using for their wakes.  I've since checked out the ships and see no difference from the ship wakes before.
LouP
« Reply #11 on: August 16, 2017, 06:55:53 PM »
Hi LouP,
A little confusion on my part as you never mentioned what specific effect file you changed.   Did you change a specific effect file that came with Voo's Heat Shimmer or something else? What was the name of it?
« Reply #12 on: August 16, 2017, 08:22:31 PM »
Can you get in touch with the Hovercontrol admins?  They could help you much better than we can.  ;)
LouP
« Reply #13 on: August 16, 2017, 10:39:17 PM »
Hi LouP,
Hi Rod,
The change I made was to the file named "voo_heat_shimmer_helo1.fx".  That shimmer effect has a downward effect to replicate the rotor wash on the heat shimmer.
LouP
« Last Edit: August 16, 2017, 10:41:19 PM by LouP »
« Reply #14 on: August 17, 2017, 07:07:21 AM »
Hi LouP,
Thanks for the clarification.  That change definitely will not affect ship wakes.
