Author Topic: vertical wave effects  (Read 3807 times)
LouP
« on: August 10, 2017, 11:30:07 AM »
Anyone seeing vertical wave effects that come up out of the water in the Sitka area in p3d v4 (no Tongass installed yet) and is there a fix?
Thanks,
LouP
Re: vertical wave effects
« Reply #1 on: August 10, 2017, 01:07:27 PM »
Hi this problem was evocated by JEFF .
your slider Water, be more lower than high for this effect ..
« Reply #2 on: August 10, 2017, 02:03:16 PM »
Here is the thread that Patrick is referring to....
http://forum.mistymoorings.com/index.php?topic=3497.30
See reply #33
« Reply #3 on: August 10, 2017, 09:15:02 PM »
     Turning the slider down to high was a temporary fix.  If you read further down the thread you'll find this ...
Quote from Dex in reply #36 of the "No Wakes" thread (concerning vertical waves in P3Dv4):
Orbx has issued Vector for P3Dv4.  After installing, I went to Kodiak and was plagued with vertical surf.  I went to another area and saw them in that location.  Went to the Orbx site and found the fix.  This fixed it for me.
"Please try re-installing the libraries.
You can do this by deleting
ORBX\User Documents\Versions\FTX_AA_ORBXLIBS.TXT
This will update the libraries again without a massive download."
     I now have my water setting at Ultra, and my waves are normal.   ;) 8)
« Last Edit: August 10, 2017, 09:17:54 PM by jeff3163 »
LouP
« Reply #4 on: August 11, 2017, 06:46:20 PM »
Thanks guys, the ORBX fix worked perfectly.
