Author Topic: Missing something  (Read 2060 times)
  • RTMM Library Manager
Re: Missing something
« Reply #15 on: August 04, 2017, 07:02:50 PM »
Hi Tom,
If you're missing #10, #11 then you definitely have a library installation problem. Make sure they are activated in your scenery library and that the scenery library points to the folder correct locations in which they're installed.
FWIW, the Medical and APP Temp libraries were combined a while back into a single library, RTMM Medical and APP Libraries FSXP3D. The info under the scenery tester still referring to them as "Temp" libraries is outdated and needs to be changed. Look for it in the Object Libraries section under the scenery tester.
THibben
« Reply #16 on: August 04, 2017, 11:15:21 PM »
Hi Steve,
It is fixed, all of the objects are present in the Scenery Object Tester.  I think what happened was I had the RTMM Medical Facilities Temp Library in a sub library to the Addon Scenery library.  I moved it up and all appears normal now.  It must have had an effect on the Alaska Power Project also because it is there.
Thanks for your help.
Tom
Tom
