Hello jett3163,
I downloaded and copied the minipni cab file and the waterrudder switch cab file and copied each to my Grumman Goose panel file. Switch 4 now brings up gauges 00,01,02,03, and 06. Activation of the water rudder switch turns on the adjacent green light but does not deploy the water rudder. I have added the following line to the bottom of the [contact_points] section of the aircraft.cfg file:
//Water Rudder by Jeff Greene
point.9=5, -15.5, 0.0, -2.1, 0, 0, 0.0, 45.00, 0.00, 0.0, 1.00, 5.0, 5.0, 5, 0, 0
Is there anything else needed to get the a water rudder to deploy? You have gone the distance to help me.
It may be that I need to accept the Goose's water taxi as is.
Thanks for your time,
WilliamB
