Author Topic: Win10 pro 64 - Bluescreen loop  (Read 20559 times)
Lipra
Re: Win10 pro 64 - Bluescreen loop
« Reply #15 on: June 21, 2017, 12:04:05 PM »
Well,
Disconnecting the drives didn't work, too.
I got the correct drive name for the C: drive but windows didn't start.
Also all repairs of mbr failed.
I guess, next try is a complete reinstall of windows .... :o :(
I think you need to test the drive b4 you put too much data back on. Maybe invest / borrow as I said earlier a spare drive with an operating system on it. If you know the make of the drive and have access to another computer they may have a repair disk you can use. I have formatted and restored an OS b4 only a week later get the same problem
Lipra
« Reply #16 on: June 21, 2017, 12:12:20 PM »
just had a few minutes to spare and googled " win10 cannot start because of system thread exception not handled" as you reported. Can you boot into safe mode at all if so maybe try a system restore.
« Reply #17 on: June 21, 2017, 03:01:46 PM »
No, I tried safe mode a dozen times.....and didn't work.
Each time I get the bluesreen with the reported error message.
Lipra
« Reply #18 on: June 22, 2017, 07:38:23 AM »
This is one of the threads I have been looking at. It shows another command to try. I have never tried this so cant vouch for it. try at own risk. I definatly would not use the tool they are trying to sell unless someone can say its safe and may work.
http://windowsreport.com/system-thread-exception-not-handled-windows-10/
« Reply #19 on: June 22, 2017, 07:40:03 AM »
For OOM or an other crash PC
Whocrashed help you
http://www.resplendence.com/whocrashed
Lipra
« Reply #20 on: June 25, 2017, 07:06:17 AM »
I came across this when I googled "repair master boot record".
  1)bootrec /RebuildBcd
  2)bootrec /fixMbr
  3)bootrec /fixboot
You need to run whis from the dos prompt. Again never tried so use at your own risk.
My gut feeling is the software install has damaged the video drivers.
« Reply #21 on: June 25, 2017, 07:19:06 AM »
How's he supposed to do this from a DOS prompt if he can't even boot into safe mode? If he hasn't already done so, he should create the Ultimate Boot Disk/Linux disk that I mentioned in reply #8 and start from there.
« Reply #22 on: June 25, 2017, 07:48:48 AM »
Hallo All,
thank you so much for all your help and advice...
But nothing Helped so far. I got c: Drive name back when disconnecting my ihrer Drives.
But I didn't get windows booting again.
I decided now to do a reinstall of windows.
BBQSteve
« Reply #23 on: June 25, 2017, 09:00:33 AM »
Under the repair utility all drive letters will change. The temp OS your system is operating under has it's own scheme based on what port your drives are plugged into and not their original drive letter. they will return when you get your system up and running.
I have had this problem and it happened the same way as you describe only with a different device. I only wish I could remember the method I used to fix it. It was a  driver problem and I am sure it was my nVidia driver. It was a lot simpler than I thought it would be and did not involve re-installing windows or everything else, I will try to find that solution for you, but you search as well.
Here is a start: https://answers.microsoft.com/en-us/windows/forum/windows_10-windows_install/win-10-reboot-loop-of-death-system-thread/dd62b9d9-e593-4a1b-a9cf-3f71e1793a1a
And here: https://www.drivereasy.com/knowledge/fix-system-thread-exception-not-handled-bsod-error/
https://www.vrheads.com/why-youre-seeing-system-thread-exception-not-handled-after-oculus-update
Ah, last but not least, a system restore! I hope you have a good recent Windows Restore point. Usually prior to an update windows will make one, but hopefully you will have a more recent one.
« Last Edit: June 25, 2017, 09:35:12 AM by BBQSteve »
Lipra
« Reply #24 on: June 25, 2017, 12:36:34 PM »
Thanks for that bbqsteve.
I said earlier that my gut feeling was NVidia drivers but looking at your final info they suggest usb problems. I wonder if everything is pulled out of the usb ports if the PC will boot. The problem we are having is getting into the system. I think its worth pulling the mouse etc. just in case
« Reply #25 on: June 25, 2017, 02:15:49 PM »
there is 2 reasons
one /  the C:/ is full
two/   some malware .
3 i don't know  :o
BBQSteve
« Reply #26 on: June 25, 2017, 04:22:22 PM »
Neither is the case Neptune.
Run your repair disk and go to advanced diags. It will then take you to where you can pick a restore point or last good system backup. I can't remember the exact procedure, so google it.
« Reply #27 on: June 25, 2017, 06:31:25 PM »
     ... you know, if Klaus is reinstalling his operating system he won't see your message until it is too late.   :P
(but I think you are on the right track, BBQSteve ;) )
« Reply #28 on: June 25, 2017, 06:50:27 PM »
Well, Klaus has been posting here even though his Win10 system is trashed, so he's obviously using a laptop, his phone or some other device to communicate with us. Therefore he's been able to read our suggestions and might see the latest.
Lipra
« Reply #29 on: June 26, 2017, 08:12:59 AM »
in reply no 13 corbu1 states that he can see the drives from the boot disk that's my only source of information. You have to be guided by what people say.
Thanks for the url to the boot disk I must try it out some time
