Author Topic: Tongass Fjords - FYI  (Read 6905 times)
plug_nickel
« on: May 28, 2017, 03:00:41 PM »
http://fssupport.com/fsaddonforum/index.php?topic=122.0
plug_nickel
addendum:
https://www.avsim.com/forums/topic/510724-a-word-of-caution-when-updating-add-ons-in-v4/
It just seems to be getting better and better. I for one will not be spending any money on V4 until it's fully fleshed out including compatibility issues.
« Last Edit: May 28, 2017, 08:20:05 PM by plug_nickel »
Re: Tongass Fjords - FYI
« Reply #1 on: May 28, 2017, 04:10:38 PM »
Thanks.  :)  8)
« Reply #2 on: May 31, 2017, 12:05:35 PM »
Quick update.....working with Dex on fixing AI aircraft missing wheels in TFX.  It is looking good so far....
RCFlyer
« Reply #3 on: May 31, 2017, 12:29:32 PM »
So TF is being updated/revised to work with P3dV4 or does it work for the most part right now?
Danny
« Reply #4 on: May 31, 2017, 04:03:54 PM »
Per Dex, TFX works pretty well with P3D v4.  Some issues with the FS9 AI airplane models missing wheels, props etc. but that is minor.  We are testing to see if we can fix any of those missing components.  Some success and some failures...but other than the AI model issues, TFX looks pretty good so far.
Bushido
« Reply #5 on: May 31, 2017, 04:27:19 PM »
I have tried to install Tongas on P3D V4 (it's my first P3D experience)
I follow the guide on Avsim, I copy paste the relevant files from my FSX folder to P3D but I have constant CTD when flying in the area.
Might be the unicode stuff in the terrain CFG that cause the issue, I don't know.
If you try to take off from PAWG is it working for you ? (I have immediate CTD for my part)
plug_nickel
« Reply #6 on: May 31, 2017, 11:22:18 PM »
Man are you guys are fast or what!!!! I just might have to bite the bullet on v4 once FTX Central 3 is updated and tested to copy files correctly.
Bushido:
You can use Notepad++ and the plugins from Sourceforge to compare character or form discrepancies between text files and it's free.
plug_nickel
Bushido
« Reply #7 on: June 01, 2017, 04:24:55 PM »
It was an issue with the AI traffic
Using the Tongass Configurator I try the various AI traffic and the culprit is the DHC 3 Otter and DH6 Twin Otter.
If the box is checked P3D crashed if uncheck no issue.
Other AI traffic seems to work fine (I didn't try the Dash 7 and Bell 206 as they are FS9 portover)
« Reply #8 on: July 09, 2017, 10:25:51 PM »
We have converted the two DHC3s, the DHC6 and the Dash 7.  They are all running beautifully in P3Dv4.  Release package is in final beta test.  See this thread for additional information:
http://forum.mistymoorings.com/index.php?topic=3463.msg30803#msg30803
