Author Topic: textures Desperate Moose Lodge PF33  (Read 3461 times)
jgisbert
« on: May 23, 2017, 10:26:33 AM »
Hola amigos:
Tras instalar Desperate Moose Lodge PF33 me encuentro con que las te3xturas de angares, conos y otros objetos aparecen en negro.
Tengo instalado las librerias de RTMM, las de OZx Na, Ez, y RWY 12.
Cuales me faltan?
Gracias
Hello friends:
After installing Desperate Moose Lodge PF33 I find that the interfaces of angles, cones and other objects appear in black.
I have installed the RTMM libraries, OZx Na, Ez, and RWY 12 libraries.
What are I missing?
Thank you
Re: textures Desperate Moose Lodge PF33
« Reply #1 on: May 23, 2017, 11:42:38 AM »
Are you sure you have ALL the RTMM Libraries?  Sounds as if you may have missed some.
« Reply #2 on: May 23, 2017, 11:47:11 AM »
Obviously your libraries still contain outdated libraries like EZ and RWY12.
The new RTMM libraries contain all of them in a new compiled version for FSX and P3D.
Please check again your RTMM libraries following the remarks made here:
(And you have to delete all outdated libraries.)
jgisbert
« Reply #3 on: May 23, 2017, 02:42:07 PM »
Ok. Perfect. Thanks
« Reply #4 on: May 23, 2017, 10:23:44 PM »
The library installation can be a little confusing to a newbie as it involves installing new libraries as well as deleting old ones. Just follow the detailed installation instructions to the letter and you'll be fine. When finished, pay attention to what libraries you have remaining. All pertaining libs should have FSXP3D in the title. Libraries without that tag should be gone after the installation.
