Author Topic: FSX will not start  (Read 10863 times)
Re: FSX will not start
« Reply #15 on: April 02, 2017, 06:58:02 PM »
Ok.  Good luck with the repair.   ;)   A repair should fix it.  Let's hope so.  Did you go through the links Steve posted about FSX CTD?  ???
John
« Reply #16 on: April 02, 2017, 09:46:41 PM »
Yes, I did a lot of reading and watched a few videos on YouTube  :D experimented a little but still can't figure things out  >:(
John
« Reply #17 on: April 03, 2017, 08:52:26 AM »
Did you try the logbook repair that I suggested?
« Reply #18 on: April 03, 2017, 11:04:24 AM »
John,
remember that a repair will delete all the ORBX FTX Global Base textures and replace them with the FSX Default texture.  You will need to re-install FTX Global Base after the repair.
One more thing if you have Acceleration installed that needs to be de-installed before the repair and re-installed afterwards.
Nothing is simple with M$!
John
« Reply #19 on: April 03, 2017, 03:51:44 PM »
Steve, logbook was ok, thanks  8)
Spud, I remembered the texture thing  ;D but didn't do Acceleration  ::) maybe that's why repair didn't work  ??? will redo  :(
John
Lipra
« Reply #20 on: April 05, 2017, 05:58:21 AM »
John
Have you tried to run fsx, with the pc in safe mode.
also have you reseated your ram [ unlikely but possible ].
install and run ccleaner to clean the registry. Take back up of registry
« Last Edit: April 05, 2017, 06:14:12 AM by Lipra »
John
« Reply #21 on: April 05, 2017, 03:01:41 PM »
Lipra
Never thought about running in safe mode  ??? ram is good  ;D I have ccleaner and clean registry on regular basis  ;) my redo of repair seemed to work, did short flight last night and seemed all ok  8)
Thanks to all with input  ;D ;D
John
ryapad
  • Site Contributor
  • Ryan Padgett
« Reply #22 on: April 05, 2017, 03:58:13 PM »
Glad you got that fixed. It's great when a problem is fixed.
« Reply #23 on: April 05, 2017, 07:47:50 PM »
Yay!  Glad you got it fixed, and are flying again.   8)   :)
John
« Reply #24 on: December 09, 2017, 11:34:33 PM »
Hello everyone, back again with same problem.  Here is my latest mess:
Problem signature:
  Problem Event Name:   APPCRASH
  Application Name:   fsx.exe
  Application Version:   10.0.61637.0
  Application Timestamp:   46fadb14
  Fault Module Name:   KERNELBASE.dll
  Fault Module Version:   6.1.7601.23915
  Fault Module Timestamp:   59b94abb
  Exception Code:   e06d7363
  Exception Offset:   0000c54f
  OS Version:   6.1.7601.2.1.0.768.3
  Locale ID:   1033
John  :'(
« Reply #25 on: December 10, 2017, 08:47:27 PM »
Lipra
« Reply #26 on: December 12, 2017, 07:56:34 AM »
John
can you get a edge connector cleaning pad from your local computer shop and double clean and re-seat the memory chips. Not sure if windows 7 has  memory check tool but you could try that it may show a problem. if you are still having problems then swap around your memory chips and see if the problem changes. you could also clean and re-seat your graphics card.
If possible can you borrow a couple of memory chips and substitute.
check the hard disk for errors
« Reply #27 on: December 12, 2017, 08:12:51 AM »
Edge connector cleaning pad?  I've always used the eraser from a No.2 pencil.   ;)
« Reply #28 on: December 12, 2017, 12:22:16 PM »
I would think that if he is having a memory chip issue it would affect a lot more things than just FSX and would crash all kinds of other programs. Generally a faulty memory chip will cause a BSOD.
John
« Reply #29 on: December 12, 2017, 05:42:12 PM »
Hi all, I am having problems with other programs  :o I'll fiddle with the memory chips when I get a chance, thanks  ;)
John
