Author Topic: FSX will not start  (Read 10978 times)
John
FSX will not start
« on: March 31, 2017, 06:25:56 PM »
I'm thinking I have a corrupt fsx.exe  :'( can anyone help me by sending a good one  ::) or let me know what else to do  :(.  Thanks
John
Re: FSX will not start
« Reply #1 on: March 31, 2017, 06:37:19 PM »
Hi John,
     I wouldn't think the executable is corrupt.  More likely a flight file is corrupt.  Rename your FSX.cfg to FSX.cfg.off, and see if the sim starts.  It will rebuild a new FSX.cfg file.   ;)
« Last Edit: March 31, 2017, 06:41:20 PM by jeff3163 »
John
« Reply #2 on: March 31, 2017, 07:41:51 PM »
Thanks Jeff  ;) I'll give it a try  ::)
John
« Reply #3 on: March 31, 2017, 08:04:20 PM »
Can also be a corrupt logbook. Do a google search on that topic. I used to have a utility that would repair it, but it went into the ether some time ago.
John
« Reply #4 on: March 31, 2017, 08:13:19 PM »
Didn't work Jeff  :( this is what I'm getting:
Problem signature:
  Problem Event Name:   APPCRASH
  Application Name:   fsx.exe
  Application Version:   10.0.61637.0
  Application Timestamp:   46fadb14
  Fault Module Name:   ui.dll
  Fault Module Version:   10.0.61637.0
  Fault Module Timestamp:   46fadb59
  Exception Code:   c0000005
  Exception Offset:   0003c963
  OS Version:   6.1.7601.2.1.0.768.3
  Locale ID:   1033
Additional information about the problem:
  LCID:   1033
Read our privacy statement online:
  http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
  C:\Windows\system32\en-US\erofflps.txt
ualani, I'll chk on the logbook, thanks  :)
John
« Reply #5 on: March 31, 2017, 08:29:00 PM »
It says the faulting module is "UI.dll".  Do a Google search for "Fault Module Name:   ui.dll"
John
« Reply #6 on: March 31, 2017, 09:45:10 PM »
Jeff, I read a few forums about UI.dll.  Wonder if you could send me a good copy of it?  It's in the root folder, if you still have Acceleration.  Hoping that might work  :-\
John
« Reply #7 on: March 31, 2017, 10:27:44 PM »
John
Hi John,
     Check your messages.  I've sent you a link.  Let me know if it works for you.
Lipra
« Reply #8 on: April 01, 2017, 08:19:43 AM »
Hi John
What operating system are you using. I hope Jeff's ui works for you if not try reseating your memory boards I am trying to find out about the   Exception Code:   c0000005 /  Exception Offset:   0003c963 and decode the offset part to see what is going on. The exception code would suggest a memory problem the exception possible being the actual location its trying to use.
Nb. I'm was not a computer engineer but was a network engineer on mobile and fixed line telephone exchanges so have a bit of an intrest in decoding these error messages for old time 's sake
« Reply #10 on: April 01, 2017, 01:17:05 PM »
John,
I attempted to send a copy to you yesterday but even .zipped or .rar its too large for an attachment and I'm not savey enough to know how to send larger files, sorry.
 8) 8)
John
« Reply #11 on: April 01, 2017, 02:37:32 PM »
Hi John
[/quote]
I'm using Win7 64 bit....Jeffs ui didn't help  :'( Thank you for your interest  ;D
John
John
« Reply #12 on: April 01, 2017, 02:44:08 PM »
Thanks Steve, I'll read up on it more  8)
Jeff, your file didn't help  :( thanks for trying  ;D
John
« Reply #13 on: April 01, 2017, 03:57:25 PM »
Yep, I didn't think anything was wrong with the file.  Something caused it to crash.  Need to find out what that "something" is.  Find out what UI.dll does, exactly.   What were you doing before the problem showed up?  ???
John
« Reply #14 on: April 02, 2017, 04:41:38 PM »
Hi Jeff, been trying to remember but it's been a few days since last flight  :( hard to pull that stuff up again  :'(
guess I'll have to try a repair, hope not a reinstall  ::)
John
