Author Topic: The latest library updates for parts 1,2 and 3  (Read 4225 times)
GrayRider
« on: March 04, 2017, 04:09:45 PM »
I downloaded the latest updates/changes for parts 1,2 and 3 of the library's. I'm not really sure what I'm supposed to do, updating the library's I already have. The RTMM library's I currently have, I've had for quite some time, and kept them updated as required for my FSX.
I'm not sure how to add/update the parts 1,2 and 3 of the library's, or what I should be doing.
I'm still an FSX user. I don't use DX10.
I'm adding a screenshot of the RTMM Library's I have installed in my FSX. All the library's of the past to present are within the library's seen in the screenshot, and are activated in my FSX. So. I'm not sure if mine are consolidated or non-consolidated RTMM library's. I'm still looking at the readme for the RTMM Library Part 1. I guess I don't quite understand what I should be doing, or how to proceed with the install, of the RTMM Library, parts 1, 2 and three.
I don't want to make any mistakes, that's for sure>
GrayRider
« Last Edit: March 04, 2017, 04:11:40 PM by GrayRider »
Re: The latest library updates for parts 1,2 and 3
« Reply #1 on: March 04, 2017, 04:49:34 PM »
Hi Gray Rider,
The update was to add a new warning messages about usage of the files.  The Part 1, Part 2 and Part 3 libraries have not changed at all.  So, the good news is there is nothing for you to install.  Just delete what you downloaded.
GrayRider
« Reply #2 on: March 04, 2017, 07:12:04 PM »
Thanks Rod. That's a relief.
I guess I was concerned about the update dates of the RTMM required Object Libraries FSXP3D Part 1, 2 and 3 downloads.
Part 1 in particular. I did read the NOTAM that shows. It mentions the AhZx Sub Library added two files: FSXP3D Kh_grasses_Lib.bgl and FSXP3Dkh_Ymry_Lib.Bgl.
I'll make sure these two files added from the Part 1 update.
I'm assuming my screenshots show I have what I should have installed, as in the past etc.
Other than that. I'll delete the three Library parts downloads I did earlier.
Thanks a heap Rod
GrayRider
« Reply #3 on: March 04, 2017, 08:10:05 PM »
Your screenshots look fine.
GrayRider
« Reply #4 on: March 05, 2017, 09:42:36 AM »
I'm back to normal. The two .bgl's in question are there etc.
Thanks Rod.
GrayRider
« Reply #5 on: March 05, 2017, 12:03:43 PM »
Glad all is good!
