Author Topic: Installing New Libraties BWEB  (Read 668 times)
Garciamk4
« on: January 24, 2017, 01:56:21 PM »
Question about installing the new BWEB and Medical App Library Objects
1.) RTMM Medical and APP Libraries FSXP3D 1-6-17.zip
2.) FSXP3D WH_BWEP Objects_SW 1_22_17.zip
I Have marked in (RED) what I believe are the Sub Directories that need to be Removed  and Marked in (Black) what should be left alone Before installing and Activating the New OBJ Libraries Above per Instruction. I just wanted to make sure I'm doing this correctly and Avoid an Oops i shouldn't have done that moment.
Thanks in Advanced  :)
« Last Edit: January 24, 2017, 02:04:35 PM by Garciamk4 »
Abel R. Garcia
Sim Platforms FS9,FSX DX10 Mode,SweetFX Core 2 Quad Q9650, GF 4GB GTX970 , 8GB System Memory Win 7 64bit
Re: Installing New Libraties BWEB
« Reply #1 on: January 24, 2017, 03:41:41 PM »
Simply put, do things in this order:
With your sim running, go to your scenery library and remove the APP Temp and Medical Temp libraries.
Remove your BWEP Object library.
Hit OK to rebuild your library index.
Delete those libraries from you hard drive; they are obsolete and not needed any more.
Install the RTMM Medical and APP Libraries FSXP3D 1-6-17.zip library and activate it in your scenery library.
Install FSXP3D WH_BWEP Objects_SW 1_22_17.zip library and activate it in your scenery library.
If you use the Scenery configuration Editor you can do all of that without the sim running.
Garciamk4
« Reply #2 on: January 24, 2017, 04:00:53 PM »
Thank you Steve Really Appreciated :)
Abel R. Garcia
« Reply #3 on: January 24, 2017, 07:48:41 PM »
Abel, I noticed on your screenshot that you have the RTMM Medical Facilities folder marked for deletion. I don't think that's correct. I believe the only folders you are to delete are:
RTMM APP Library TEMP
RTMM Medical Library TEMP
BWEP Object Library
Somebody correct me if I'm wrong but I never saw where the RTMM Medical Facilities were to be deleted.
« Reply #4 on: January 24, 2017, 08:01:20 PM »
You are correct J.J.
« Reply #5 on: January 24, 2017, 08:17:56 PM »
Thanks Steve, I was hoping you'd reply b4 he hits the Delete button. I just happened to check out his screenshot because I am just now getting into BWEP myself, and when I saw his post I thought, delete files...what files? Better delve into this a little further. What's that commercial? Miss a day, miss a lot. That's no joke around here. Life in the fast lane.  :)
JJ
Garciamk4
« Reply #6 on: January 24, 2017, 08:34:15 PM »
BWEP Object Library
Thanks for the Update JSPAIR I made sure no to delete that folder  8)
Abel R. Garcia
« Reply #7 on: January 24, 2017, 08:55:47 PM »
That's my good deed for the day. Tomorrow I'm up to mischief.  ;)
Garciamk4
« Reply #8 on: January 24, 2017, 09:27:07 PM »
Lol
Abel R. Garcia
