Hello jsapair,
I checked my C185 in FSX and all repaints are shown as it should.
the jpg-files for the BWEP C185`s can go into the root Folder of the Carenado C185.
Did you copy and paste the complete aircraft.cfg entries for the different BWEP C185 variants into the aircraft.cfg`s of your sim?
Example for the amphibian BWEP C185 - copy and paste this to your Carenado C185 amphibian aircraft.cfg:
[fltsim.x] //note: for x add the next highest number in your aircraft.cfg
title=C185F SKYWAGON AMPHIBIAN BWEP NC185MM
sim=Carenado_C185
model=
panel=
sound=
texture=NC185MM
kb_checklists=C185_check
kb_reference=C185_ref
atc_id=NC185MM
ui_manufacturer="Carenado"
ui_type="Amphibian C185F"
ui_variation="AMPHIBIAN"
ui_createdby="Carenado"
ui_typerole="Highwing single Engine Prop"
description="This is a repaint of the Carenado Cessna C185F representing the fictitious C185F of Blue Wave Energy Partners (BWEP) by Return to Misty Moorings. see homepage under
www.return.mistymoorings.com."
atc_heavy=0
atc_airline=
atc_flight_number=
atc_id_color=0x00000000
atc_id_font=Verdana,-11,1,600,0
visual_damage=0
