Ryan,
There's quite a few textures associated with this.
EZ_2_Light_Bark.dds
EZ_2_Light_Bark_Pine_Grooved.dds
EZ_2_log_end_2.dds
EZ_2_Weathered_wood_3.dds
EZ_2_Weathered_wood_Mahogany_planks.dds
ez_lodge_1.dds
ez_lodge_1_door.dds
ez_lodge_1_door_lm.dds
ez_lodge_1_lm.dds
ez_lodge_1B.dds
ez_lodge_2_door.dds
ez_lodge_2_door_lm.dds
ez_lodge_2B.dds
ez_lodge_2B_lm.dds
EZ_Shingle_2.dds
EZ_Shingle_2_lm.dds
EZ_wood_panel_1.dds
Len-brick2 mid.dds
Len-brick2 mid_lm.dds
This raises a question: Are you moving the textures to a different folder from the original texture folder located in the RTMM Object LibraryFSXP3D texture folder for some reason? I'm asking because since you have the object, which is the black blob, and the textures aren't showing, I'm thinking that maybe you've separated the two related sub folders, scenery and texture. I'm also wondering about this because in your past issue you mentioned something about copying textures, which you shouldn't need to do. (Unless you unzipped the downloaded library somewhere else and copied the entire library, lock, stock and barrel, as is into your Addon Scenery folder.)
Your folder structure should look like this:
RTMM Required Libraries Part II
Scenery
Texture
All of your textures should be in the texture sub folder, stay in there, and not moved to anywhere else.
