Ok...tell you what, I can use my new StarWars transporter I got for Christmas to put a fuel station at payware PAVD. You folks tell me exactly where you want it, I'll put in the coordinates and transport it. First, make sure you can give me the coordinates with 4 digit accuracy.
To do this: Go into the Prepar3d.cfg or FSX.cfg files and add this under [MAIN]:
[Main]
FractionalLatLonDigits=4
Restart the sim. Now look at your lat/long, it should give you four digit accuracy.
With slew, put your aircraft where it would be positioned to receive fuel.
Now in top down view, slew your aircraft up till it doesn't show, showing only the red crosshairs
Slew the cross forward to the exact spot where the fuel pump should be.
Note the 4-digit latitude and longitude AND the heading. Email me all three numbers.
I'll put the fuel pump in the new transporter and send it to you.
Talk among yourselves here for the best position. It's a big airport, no problem with two of them. The transporter can handle multiple objects. Remember, I'm back at RTMM central and cannot see what you are seeing. So agree in the coordinates. When I see you agree in the positioning, I'll transport them for you.
