Sue, no joy on the panel change. Re-named the old and installed the new in all 4 panel folders. No differencia (a little Spanish lingo). Seems to me these gauges worked when I first installed the package years ago. Also seems to me that they worked immediately after re-installs, but then the problem came back upon re-starting FSX. But I also thought it was called the Apache Warrior Project. LOL.
Found it again, 'Piper APACHE Project' over at flyawaysimulation. No floats, though, just the liveries I posted. I've re-installed it several times over the years with the same results which is why I gave up. Maybe I could try a new DL from a different place.
There is a custom.cab file in the panel folders as well. Should that be unzipped? Don't recall ever having to unzip one b4, though.
Thanks for your time and trouble. Appreciate it. Back to square one. I'll look around. If need be I'll PM you and take you up on your offer.
