Author Topic: Repaint FIX for C 185  (Read 5575 times)
DocScott
« on: November 22, 2016, 12:00:51 PM »
Hi there!
I downloaded the repaint for the C 185 MM016, but the No on the left tail is reproduced in mirror image.
I couldn't find a fix for it, here in the forum.
Any help would be appreciated.
Regards,
DocScott
I am dreaming of a visit to Alaska in winter time.
Staying with friends and enjoying nature.
Re: Repaint FIX for C 185
« Reply #1 on: November 22, 2016, 12:22:43 PM »
Doc,
the tail logo on the C-185 MM016 is not reversed on the download I just installed BUT the prop is not transparent on this and MM015 and I don't recall how a black prop disc can be fixed.  Anyone?
Prop disc fixed.  Had another repaint of the C-185 Tundra that had a good prop disc.  Looked in the texture folder and found a file (PROP.bmp) and added it to the 015MM and 016MM repaint texture folders and it worked.
OOPS!  Just found out that for some reason the cockpit interiors are all black with the instruments showing but no outside view at all.  I guess these repaints have some problems.  Carenado does strange things to the way they paint their A/C.  At least that's what I read.
Anyone have these repaints the work correctly in all views??
« Last Edit: November 22, 2016, 12:45:13 PM by spud »
« Reply #2 on: November 22, 2016, 04:06:04 PM »
 8) Yeah, after I read the instructions. I started out doing the same thing you did- dropped the texture in, added the appropriate lines to the cfg file and jumped in the plane. Oops, black interior. The instructions-
"1. Go to your "SimObjects" folder inside FSX.
2. Locate the "Airplanes" folder.
3. Then the aircraft named "Carenado C185F Tundra"
4. Copy the folder named "Texture" and all files in that folder from the "Carenado C185F Tundra" main folder to your desktop.
5. Copy and paste the texture files found inside this zip named "texture.N016MM" into the temporary "Texture" folder you just placed on your desktop.
6. Overwrite any files that you are prompted to overwrite.
7. Rename the "Texture" folder on your desktop to "Texture.N016MM"
8. Move that folder back into the SimObjects/Airplanes/Carenado C185F Tundra model main folder.
9. Move the "thumbnailn016mm.jpg" from this zip to your Carendado C185F Tundra model main folder.
10. Copy and paste the config data below to your aircraft config file below the last similar entry with a space between.
11. Edit the [fltsim.X] part of the newly added config data you just copied to the next number in sequence.
12. Save the aircraft config file."
   Since I already have the texture in the sim, I simply opened up the C-185 Misty 016 folder, and the Texture folder, clicked "select all" in the Texture folder, and dropped them in the 016 folder. Tell it NOT to over write. Worked for me.
 LOL
« Last Edit: November 22, 2016, 07:54:43 PM by Penzoil3 »
« Reply #3 on: November 22, 2016, 07:46:27 PM »
   ... the instructions ...  ;D  Wierd, huh Spud?   :o   ;)
Thanks Sue!   8)
« Reply #4 on: November 23, 2016, 11:11:51 AM »
Don't understand what the problem is/was but downloaded the re-paints again today and after two unsucessful attempts (following the instructions again.  I finally got the cockpit to show.  I sure hope this isn't an indication I've got FSX problems again.
OK off to re-attempt N016 now.
« Reply #5 on: November 23, 2016, 03:10:30 PM »
 The instructions are a bit convoluted, so I used "shop math", as any good mechanic would.
 LOL
« Reply #6 on: November 24, 2016, 11:07:16 AM »
Is 'shop math' anything like the USMC method of slip it weight and balance?  Slip it in and if it flies its not too heavy!.
« Last Edit: November 24, 2016, 11:41:16 PM by spud »
« Reply #7 on: November 24, 2016, 03:59:27 PM »
Sort of. It's how you do math old style, as opposed to the new way taught in school.  Umm, short version.
35x 4.   3x4 is 12,  5x4 is 20, answer is 140. Like that.
DocScott
« Reply #8 on: November 25, 2016, 03:55:22 AM »
Well,when  that isn't  a mirror image???
Can't see any problems with the propeller!
Regards,
DocScott
P.S Is it possible that there are two places for the download,although I only saw one.
« Last Edit: November 25, 2016, 04:02:39 AM by DocScott »
« Reply #9 on: November 25, 2016, 01:59:00 PM »
Doc,
strange, here is shots of the A/C I have installed from the repaint download.
Click Enhancements then Repaints and that's the only one I know of.
« Last Edit: November 27, 2016, 09:42:12 AM by spud »
DocScott
« Reply #10 on: November 27, 2016, 05:31:32 AM »
Hi !
I downloaded it again,same result mirror image on the left tail.Same problem with the paint N015MM
Other repaints(not from RTMM) for that airplane are ok.
ANY ideas,why this happens?
Scott
« Last Edit: November 27, 2016, 08:07:43 AM by DocScott »
« Reply #11 on: November 27, 2016, 09:46:25 AM »
Doc,
one more question; what sim are you running?  That would be the only difference I can think of.  P3D and FSX-SE are of course animals of a different stripe in some ways.
DocScott
« Reply #12 on: November 27, 2016, 09:55:27 AM »
Hi Spud !
I am running P3Dv.3.4. But I am using a lot of old FSX repaints. :-[
Scott
« Reply #13 on: November 27, 2016, 09:59:23 AM »
Hang in there a bit longer I'm sure a P3D.4 user will have some information and jump in.  Anyone?
« Reply #14 on: November 27, 2016, 10:52:33 AM »
It shows correctly for me in P3Dv3.4.9.  Looking at the texture sheet in FS Repaint, the tail is painted in normal orientation on both sides.  Not sure what is flipping it around for you.  ???
I have seen this anomaly before, but is not happening to me with this plane.  Sorry to be no help.  :-\
« Last Edit: November 27, 2016, 10:54:17 AM by jeff3163 »
