Author Topic: Red Boat Wakes at Halibut Cove  (Read 11161 times)
rgerdes
« on: November 01, 2016, 03:21:08 PM »
Hi to RTMM
Got a shiny new computer
Installed the latest prepar3d v3
Got all my ORBX stuff installed
Been installing the RTMM sceneries
Got the shipping project with the 3.1 wake fix
But when I installed the Halibut Cove scenery and went to take a look around the boats have the red wakes
I added the Ground Decal=1 to the effects file but there must be something else because I still have the red wakes.
What to try next....
Thanks,
Bob - and thanks for all your great scenery..
Re: Red Boat Wakes at Halibut Cove
« Reply #1 on: November 01, 2016, 03:45:25 PM »
Hi...do a search here for red wakes.
rgerdes
« Reply #2 on: November 01, 2016, 05:09:03 PM »
Hi Doug,
Did what you suggested and had already applied that fix
I think it only applies to the boats in the "RTMM Shipping Projects"?
Doesn't look like the boats in the Halibut Cove Scenery were included in the fix?
« Reply #3 on: November 01, 2016, 07:00:16 PM »
The boats at Halibut are using a different version of AI (like Tongass Fjords)  the wake used by the fishing boats is: fx_wake_AI_fishing Boat.fx  and the Danny J and Stormbird use fx_wake_AI_Marignan.fx
rgerdes
« Reply #4 on: November 01, 2016, 07:07:53 PM »
and those three weren't fixed?
« Reply #5 on: November 01, 2016, 07:19:07 PM »
They work for me,
« Reply #6 on: November 01, 2016, 08:05:16 PM »
Did that help?
rgerdes
« Reply #7 on: November 02, 2016, 02:26:09 AM »
not so far - but I 've decided to play with something else for awhile  :)
Think I'll install yes bay - no boats there... ;)
Thanks for the help,
Bob
« Reply #8 on: November 02, 2016, 09:06:49 AM »
The effects that I sent you are the ones that I use.  I do not see red wakes at halibut.
rgerdes
« Reply #9 on: November 02, 2016, 11:50:40 PM »
Played around with the halibut cove boats some more (stormbird and danny j) and no matter what I try I still get the red wake, Even tried completely removing the effects section from the cfg file and still get the red wake, It,s almost like the wake is hardwired into that boat.
Bob
« Reply #10 on: November 05, 2016, 03:09:57 PM »
Here are the calls from the effect file:
[Library Effect]
Lifetime=5
Version=2.00
Radius=-1
Priority=0
[Properties]
// WAKE Stern ========================================================
[Emitter.0]
Lifetime=0.00, 0.00
Delay=10.00, 10.00
Bounce=0.00
Rate=1.00, 1.00
X Emitter Velocity=0.00, 0.00
Y Emitter Velocity=0.00, 0.00
Z Emitter Velocity=0.00, 0.00
Drag=0.00, 0.00
X Particle Velocity=0.00, 0.00
Y Particle Velocity=0.00, 0.00
Z Particle Velocity=0.00, 0.00
X Offset=0.00, 0.00
Y Offset=0.00, 0.00
Z Offset=8.50, 8.50
[Particle.0]
Lifetime=9.0, 9.0
Type=21
X Scale=8.0, 10.0
Y Scale=8.0, 10.0
Z Scale=0.00, 0.00
X Scale Rate=0.06, 0.06
Y Scale Rate=0.07, 0.07
Z Scale Rate=0.00, 0.00
Drag=0.00, 0.00
Color Rate=0.11, 0.11
Fade In=0.05, 0.05
Fade Out=0.40, 0.40
Ground Normal=1
Ground Decal=1
Shade=1
Face=1, 0, 1
[ParticleAttributes.0]
Blend Mode=1
Bounce=0.00
Color Start=220, 220, 220, 80
Color End=220, 220, 220, 0
Jitter Distance=0.02
Jitter Time=1.00
uv1=0.00, 0.00
uv2=1.00, 1.00
X Scale Goal=42.00
Y Scale Goal=42.00
Z Scale Goal=0.00
Extrude Length=10.00
Extrude Pitch Max=50.00
Extrude Heading Max=10.00
// WAKE Side ============================================================
[Emitter.1]
Lifetime=0.00, 0.00
Delay=15.00, 15.00
Bounce=0.00
Rate=1.00, 1.00
Drag=0.00, 0.00
X Offset=0.00, 0.00
Y Offset=0.00,  0.00
Z Offset=9.00, 9.00
[Particle.1]
Lifetime=10.0, 10.0
Type=21
X Scale=10.0, 12.0
Y Scale=10.0, 12.0
Z Scale=0.00, 0.00
X Scale Rate=0.08, 0.08
Y Scale Rate=0.09, 0.09
Drag=0.00, 0.00
Color Rate=0.00, 0.00
Fade In=0.05, 0.05
Fade Out=0.50, 0.50
Ground Normal=1
Ground Decal=1
Shade=1
Face=1, 0, 1
[ParticleAttributes.1]
Blend Mode=1
Bounce=0.00
Color Start=238, 238, 238, 130
Color End=238, 238, 238, 0
Jitter Time=1.00
uv1=0.00, 0.00
uv2=1.00, 1.00
X Scale Goal=48.00
Y Scale Goal=48.00
Z Scale Goal=0.00
Extrude Length=20.00
Extrude Pitch Max=70.00
Extrude Heading Max=20.00
rgerdes
« Reply #11 on: November 05, 2016, 07:11:07 PM »
Hi Dexthom,
Thanks for the info - that's exactly how mine reads. Think this is a lost cause - something on my setup doesn't display the wakes on that particular boat. All the other RTMM shipping boats are right and Henrik's Global Shipping package works. It's only that one boat that is a problem.
Well, not exactly true because none of the Tongass Fjords boats have any wakes at all  ??? so It's got to be a setting peculiar to my setup.
Bob
« Reply #12 on: November 05, 2016, 09:20:43 PM »
What version of P3D are you running?  I am attaching the config file that will cover the Danny J and Storm Bird.
rgerdes
« Reply #13 on: November 05, 2016, 09:48:06 PM »
I'm running the most current version: 3.4.9
I'll take a look at the config file...
Edit: Damn  :) That was it.....!!!!
The effects section in your config was different then mine - the touchdown= section was totally different. It works now  :P
Thank you a bunch...
Got another question/request - I see you have a texture for a boat called the Dutch Treat - any chance I could get a copy of that texture please??
Reason I ask is I use to know a couple who ran a charter boat with that name - small world huh?
Thanks,
Bob
« Last Edit: November 05, 2016, 10:06:42 PM by rgerdes »
« Reply #14 on: November 06, 2016, 08:09:24 AM »
Here you go...  It's too big to attach, here's a link, let me know when you get it.
https://www.dropbox.com/s/zddnlz9lgisi5bt/Texture.Dutch%20Treat.zip?dl=0
