Hmmm....seems ambiguous since Rod also says in reply #3,
"The Season Switcher exe addresses all sceneries inside the folder it resides in and all child folders below the folder it is in."
So, it should, and does, work if it's in the root of the RTMM scenery folder as well.
I agree I probably should not have said "So a
typical path for the RTMM Season Switcher v3.3.exe ....". In my install the Season Switcher v3.3 is placed in the FSX\Addon Scenery folder because my
RTMM folder is a child folder of the Addon Scenery folder and thus the switcher will work on all my RTMM scenery that contain seasonal files.
If your installation is set up this way as recommended the switcher works fine. However if the user does not follow the recommendations from here:
http://www.return.mistymoorings.com/object_libraries_build/ (scroll down to section 1 'Scenery Folder Placement')
Then the switcher may not function as it should.
If the switcher is placed in a
'parent'RTMM folder which contains the RTMM scenery locations then it will indeed change all RTMM locations with seasonal files, but only in the RTMM 'parent' folder.
However if the user does not use this method/location for his RTMM scenery the switcher will not function. And unfortunately we do have user's that forego instructions and use a non - standard location for RTMM scenery.
