Author Topic: Blue Wave Energy Partners - is LIVE!  (Read 256950 times)
Re: Blue Wave Energy Partners - is LIVE!
« Reply #60 on: October 18, 2016, 01:40:18 PM »
Tom,
let us know how 'goesit' and if you 'see' the scenery.  We'll git r' dun' maybe later than sooner but we'll wait for you to buy the beer at Misty's.  :o
THibben
« Reply #61 on: October 18, 2016, 03:36:57 PM »
Hi Spud,
Short answer is no.  I found #5 and #11 missing in the scenery object tester and now have them both there.  The oil storage area appears correct but there is no pipeline visible.  I flew to several points of the BWEP Pipeline Sections but found nothing visible except snow and some scattered trees.
Any help would be appreciated.
Thanks,
Tom
Tom
« Reply #62 on: October 19, 2016, 07:51:31 AM »
Hi Tom,
Can you verify that you have object 12 visible using the scenery tester?
THibben
« Reply #63 on: October 19, 2016, 10:51:05 AM »
Rod,
Yes, all objects are visible in the scenery tester.
Tom
Tom
« Reply #64 on: October 19, 2016, 11:15:32 AM »
Dumb question, but do you own ORBX SAK?
THibben
« Reply #65 on: October 19, 2016, 11:48:35 AM »
Hi Steve,
Yes I have NA Blue Southern Alaska.....and a whole lot more ORBX...grin.
Tom
Tom
THibben
« Reply #66 on: October 19, 2016, 06:59:15 PM »
Well I finally soled my problem. I had Tongass Fjords set to low in the scenery library.  I moved it up above the FSX scenery and all seems to be well.
Tom
Tom
« Reply #67 on: October 20, 2016, 10:42:28 AM »
Tom,
placement order of files in the FSX Scenery Library is crucial for correct scenery display.  To have the correct order start FTX Central and in the lower left corner click on "ORBX GUIDE".  On page 45 is a listing of the correct order of files in the Scenery Library.  Follow this 'chart' and you shouldn't have problems with scenery displaying correctly.
Do not ignore the greyed out text between entries like "named default scenery"; that would be those default entries starting with Edwards AFB and ending with Africa.  Same for the other greyed out text, be sure you have those in the correct order.
Chart:
(click to enlarge)
« Last Edit: October 20, 2016, 10:53:01 AM by spud »
THibben
« Reply #68 on: October 20, 2016, 02:18:48 PM »
Hi Spud,
As far as I can tell it appears to be running fine.  I followed the pipeline for quite a while.  What is the latest pipeline section that is now visible?  I have been looking for that info but can't seem to find it.
Thanks,
Tom
Tom
« Reply #69 on: October 20, 2016, 03:07:50 PM »
There's only one section completed at the moment; the SAK section.
THibben
« Reply #70 on: October 20, 2016, 04:04:31 PM »
Tom
Tom
« Reply #71 on: November 13, 2016, 02:33:43 PM »
RTMM BWEP has expanded the fleet.
We now have the payware Cerasim Bell212 Twinhuey helicopter in our Hangars!
« Reply #72 on: November 13, 2016, 02:37:02 PM »
The BWEP Aerosoft BeaverX is now prepared for the winterseason with a pair of skis.
Trex3D
« Reply #73 on: November 13, 2016, 04:23:33 PM »
Absolutely beautiful & thanks again Klaus!  My 212 will love to have a fresh repaint before its next dispatch or medevac flight...   8)
« Reply #74 on: November 14, 2016, 05:43:57 PM »
 8) What BWEP Airports.zip ? (BWEP dispatch) I can't find that.
P004S    Instructions
Local Map    BWEP So Alaska: Supply Run - Deliver Electrical component to tundra strip at Pump Station #11 (06.22.2016) ... NOTAM, a redownload the the BWEP Airports.zip is necessary for this, an airstrip was added at PS11.
« Last Edit: November 14, 2016, 05:46:09 PM by Penzoil3 »
