Author Topic: Blue Wave Energy Partners - is LIVE!  (Read 256972 times)
Re: Blue Wave Energy Partners - is LIVE!
« Reply #105 on: December 25, 2016, 11:18:15 AM »
When in the case of doubt the simplest solution is to uncheck (deactivate) the installed version then install the other version.  That way you can look at the results and switch back and forth by checking one version and unchecking the other to see the differences in scenery.  Picking the one that is correct for your installation.
PAVD by ORBX was one of the rare instances where ORBX released a payware airport (and the associated terrain) at the same location as RTMM developed scenery making it necessary for the team to issue a second version of the Pipeline due to those changes.  No ORBX PAVD use the - A BWEP or SAK Only
with ORBX PAVD use - B BWEP for SAK & PAVD
Only two choices on the BWEP page, shouldn't be too hard to choose.
« Reply #106 on: January 03, 2017, 09:29:44 PM »
New Object Library issued as of 01.03.2017. Be sure to get the new library cause you never know what's around the corner or what's coming down the pipe!
updraft
« Reply #107 on: January 08, 2017, 12:11:12 PM »
Just installed the latest BWEP library.
In the RTMM Scenery Objet Tester the Vertical Tank is missing, which seems to be a BWEP object.
I don't know whether this tank was present before the latest update.
All other objects are present.
Actually I have 6 bgl files in my scenery folder, which is active in the scenery library.
I did only upgrade (overwrite) the older bgl files by the new ones.
What could be the cause for this missing vertical tank and what are the consequnces?
Thanks for your advices.
Ernst
« Reply #108 on: January 08, 2017, 12:29:21 PM »
Hi Ernst,
     You should delete and replace the old library folder with the new.  If BGL files are named slightly different, they won't be overwritten.  You would have two copies, theoretically.  So replace the entire folder, as a rule.  ;)
« Reply #109 on: January 08, 2017, 03:18:01 PM »
The only that change in the last library update from the previous one is that I created some night textures for a handful of objects (some of which will be incorporated in the Richardson Highway segment.  :)) The tanks have been in there since the very first library release and haven't been touched in ages.
As Jeff says, ALWAYS completely delete old libraries or scenery files when updating to newer versions. NEVER simply overwrite.
THibben
« Reply #110 on: January 08, 2017, 09:48:21 PM »
Hi Ernst,
This is probably a stupid question, but do we delete the files from the sim and also the original one you may have saved prior to installing? Exactly which files are we talking about?  Or is this Richardson Highway a totally new entry
Tom
« Last Edit: January 08, 2017, 09:58:39 PM by THibben »
Tom
« Reply #111 on: January 08, 2017, 10:27:36 PM »
RICHARDSON HIGHWAY IS RELEASED!!!!
Enjoy!
« Reply #112 on: January 08, 2017, 10:31:58 PM »
Tom,
Completely delete any previous versions of the BWEP object library and get rid of them lock, stock, and barrel. Download the newest version and install it. This will avoid confusion and always assure that you will have the latest and greatest.
Richardson Highway is a brand new scenery addition that uses the BWEP library objects.
updraft
« Reply #113 on: January 09, 2017, 01:50:25 AM »
I did now replaced  the entire BWEP library (FSXP3D WH_BWEP Objects_SW) by the latest one.
Still no Vertical Tank visible with the Scenery Objects Tester.
Am I the only one?
Thanks for any further help.
Ernst
« Reply #114 on: January 09, 2017, 08:24:54 AM »
The only thing I can think of is that maybe you have an older version of the scenery tester. Make sure you have the latest one on the scenery page dated 09.25.2016. Post back if you still are having issues (or figure it out.)
I just checked mine and the tank object is there.
updraft
« Reply #115 on: January 09, 2017, 04:09:30 PM »
Hi Steve,
That was it!!!
Vertical Tank is showing now.
Thank you very much!
Ernst
« Reply #116 on: January 09, 2017, 05:05:33 PM »
After banging your head into a wall repeatedly it usually turns out to being a fairly easy solution, so join the club!   Glad we got 'er done.
« Reply #117 on: January 09, 2017, 10:36:53 PM »
Asking is the key. I always cringe when somebody's first thought is to re-install FSX! Don't believe I've ever seen a problem here that wasn't resolved.
updraft
« Reply #118 on: January 10, 2017, 10:54:52 AM »
Very true! To both, Steve and jsapair!
Great addons and great community here, competent, extremely friendly and helpful.
A bit hard to find the real fitting words for me in foreign language, but I think you'll understand.
Steve: Great signature picture of a super great catch!
Thanks again and best regards
Ernst
« Reply #119 on: January 10, 2017, 02:10:38 PM »
With the release of BWEP partII: Richardson Highway we have a new helicopter in our fleet!
It`s the Cerasim Bell222B....This bird acts as our new executive Transport helicopter`s for BWEP`s big guys! 8)
This is it how the paintscheme looks like:
