Author Topic: SOLVED: Runway12 object missing  (Read 1333 times)
hjsmuc
« on: May 20, 2016, 07:20:59 PM »
Hello, I am missing the 5th object from the left in the library test scenario, i.e. the one from Runway12 library. I reinstalled all libraries, disabled oz_lib but it doesn't show up. This is on Prepar3D 3.2. Any ideas?
Many thanks for the great site and your contributions to the sim world. Can't be repeated often enough.
Cheers,
Hans
« Last Edit: May 31, 2016, 09:56:32 AM by hjsmuc »
Re: Runway12 object missing
« Reply #1 on: May 30, 2016, 05:00:49 PM »
Hi Hans,
Did you solve this problem?  You may have some old RWY12 objects (FS9) enabled that are interfering with the converted RWY12 objects (FSX) that display in P3Dv2 & 3.
hjsmuc
« Reply #2 on: May 31, 2016, 06:02:11 AM »
Hi Rod,
Unfortunately not, the RW12 object is still missing. How would I find old FS9 objects? The installation is rather fresh.
Hans
« Reply #3 on: May 31, 2016, 07:51:34 AM »
We don't know your installation but there are many, many possibilities of having former FS9 object libraries installed:
Some examples:
EZ Scenery Library
Rwy12 Library
FinneyAir_FSX_Strobe_Collection
Lens_EZ_Wilderness
UKVFR-Library
Woody's EZ_rocks_Boulders_snowdrifts
Woody's EZ_SIRP_stuff
woody_s_ez_hangers_green
woody's EZ_Waterfalls
Woody's_EZ_airport signs
Woodys-EZ_Hangars_Blue
hjsmuc
« Reply #4 on: May 31, 2016, 09:52:19 AM »
Found the culprit, it was the FSX static object library.
Thanks for pointing me to the right direction.
« Last Edit: May 31, 2016, 09:57:14 AM by hjsmuc »
Re: SOLVED: Runway12 object missing
« Reply #5 on: May 31, 2016, 10:16:12 AM »
Great!  I also used to have the FSX static object library  (a consolidation of many object libraries) but had to dump it when I moved to P3Dv2.
Thanks Dieter for your examples!
