Author Topic: Over the shoulders again  (Read 8244 times)
One-Eye
Re: Over the shoulders again
« Reply #15 on: March 07, 2011, 04:18:15 PM »
Surprisingly nice plane to play with so far. For a kero burner. I am quite enamoure of her.
All the best,
GrahamP
« Reply #16 on: March 07, 2011, 05:32:16 PM »
That's looking really nice, Chris.
A small correction though, if I may - your'e should be spelt you're.  Yes, I know I looked too close ;)
Graham
One-Eye
« Reply #17 on: March 07, 2011, 11:20:54 PM »
No problems. You're quite right and of course, the final result will be different. I am still looking at hinges and things - the text was initially onle there to show me things like which way round certain panels were - as can be seen with the pod doors.
Besides - my eyesight is failing for real. I need glasses desperately.
All the best,
One-Eye
« Reply #18 on: March 08, 2011, 04:57:24 AM »
A sort of first for me. Nothing special, but I thought I'd have a go with Snagit Video capture and for the first time I have a video file that isn't ginormous.
I just took it to show an approach and landing into Eagleskinners secret paint and sprayshop location and to give you an idea of the humpy back runway. It doesn't just slope, it rollercoasters ;) What makes it even more fun is that the high ground you approach over is just about at the same slope angle as your glideslope.
And to make matters worse, the runway is also "downhill" in an overall sense, so you really need brakes and a minimum approach speed. I've put the caravan into the water withou thrust reversers and floating too long over the runway.
http://www.youtube.com/watch?v=Fzv4DOGoypo <- it won't win an oscar...
The attached static screenies show the current state of play with the Caravan... and "What silly 'arris forgot to put the hot air balloons on NOTAMS?"
The video takes over just after that last screenie.
« Last Edit: March 08, 2011, 05:00:47 AM by One-Eye »
All the best,
