Like you I was disappointed with the floating characteristics of the Kodiak amphibian. Several years ago I started fiddling with the contact points for the floats and looking on forums, like your post here, for information. Several years ago (I don't remember when) I found some contact points on the ORBX forum. After a little fiddling with them I have come up with the following contact points. They seem to work pretty well - at least for me. There is some very slight forward tilt when slowing but overall the plane floats better in all phases of operation.
MAKE A COPY OF THE AIRCRAFT.CFG
In the Contact Points section of the Aircraft.cfg, comment out points 4, 5, 6, 7 (put 2 forward slashes "//" in front of the word "point") and paste in the following contact points.
// 1 2 3 4 5 6 7 8 9 10 11 12 13 14
point.4 = 4, 6, -5.05, -7.30, 1600, 0, 0, 0, 0.45, 0.1, 0.15, 0, 0, 3
point.5 = 4, 6, 5.05, -7.30, 1600, 0, 0, 0, 0.45, 0.1, 0.15, 0, 0, 2
point.6 = 4, -6, -5.05, -7.20, 1600, 0, 0, 30, 0.75, 2.5, 0.65, 0, 0, 3 //pos 8 = water rudder steering angle
point.7 = 4, -6, 5.05, -7.20, 1600, 0, 0, 30, 0.75, 2.5, 0.65, 0, 0, 2 //pos 8 = water rudder steering angle
I hope they work for you.
