Author Topic: Tongass X Fjords - P3D  (Read 3700 times)
Martyson
« on: October 27, 2015, 03:34:11 PM »
Hello,
I only have P3Dv3 installed now.
I was reading about Tongass X Fjords but I only see it available (sold Simmarket e.g.) for FSX.
Is it possible to get it installed into P3Dv3?
Best Regards,
Vaughan Martell (KDTW)
Re: Tongass X Fjords - P3D
« Reply #1 on: October 27, 2015, 04:48:47 PM »
Yes i do ,
its one of the first scenery i have installed
because all entries may be re number in C:/ProgramDATA/ VP3Dv3/ TERRAIN .CFG
1 of 40  to 40 of 40
// Tongass Fjords FSX custom textures 1 of 40
[Texture.383]
Name=Tongass_Utility_Corridor_Vectors
TO
// Tongass Fjords FSX custom textures 40 of 40
[Texture.422]
Name=Tongass_AutoGen_Exclude
if you don't make this your PASI Sitka sea is the forest .
Martyson
« Reply #2 on: October 27, 2015, 06:25:21 PM »
Patrick,
Glad to hear it is possible.
The renumbering ..
do you have to do this every time a new RTMM scenery (or other payware scenery) is added to the P3Dv3 Scenery Library?
Best Regards,
« Reply #3 on: October 27, 2015, 07:06:34 PM »
Vaughan,
There is a specific procedure to use when you install Tongass Fjords X into P3Dv2 or P3Dv3.  Go to the RTMM web page and look under FAQ heading.  Go to Tongass X Terrain Problem fix section.  In the middle  of that section is this sentence:
"Holger Sandmann has given us a "fix" for this if if happens to you. First, download the text file you will need HERE."
The main install procedure plus the backup Holger Sandman fix are all included in the download when you click on "HERE".  It is pretty self explanatory.  Take a look.
Note the E*T in the documentation refers to the Estonia Flight Migration Tool.  Use Version 3.0.0.926 or higher which is the P3Dv3 version (still being refined....limitations are listed via a link on Estonia's page).  Here is the link for the Estonia page:
http://www.flightsim.ee/products/migration-tool
« Last Edit: October 27, 2015, 07:14:22 PM by stiletto2 »
Martyson
« Reply #4 on: October 27, 2015, 07:31:19 PM »
Rod,
Thanks for the follow up.
I will go read.
Best Regards,
« Reply #5 on: October 30, 2015, 09:52:48 AM »
Hi
Don't miss to change the numbers total scenery you have  ;)
Here : C:\ProgramData\Lockheed Martin\Prepar3D v3\Terrain.cfg
at the top of the cfg TEXTE look here in red : (for me of course)
[General]
DefaultTextureCount=989
AutogenCount=60
« Last Edit: October 30, 2015, 09:54:54 AM by NeptuneP2V7 »
