Author Topic: Ssd Clone  (Read 10779 times)
BamaKevin
Re: Ssd Clone
« Reply #30 on: August 20, 2015, 05:03:05 PM »
heres whats weird I can run p3d on the old drive fine even though i changed the drive letter. everthing is set to default but it works.
Re: Ssd Clone
« Reply #31 on: August 20, 2015, 08:52:59 PM »
It crashes when you load a flightplan?  Can you fly if you don't load a flightplan?  Just pick a plane and a place and go.  Did you flush your shader cache folder, so it could rebuild new ones?  Are there any error messages in your "Event Viewer"?  ???
BamaKevin
Re: Ssd Clone
« Reply #32 on: August 20, 2015, 10:15:31 PM »
No it crashes after I select an aircraft and airport. No flight plan.  It gets to about 16% and crashes to desktop.  I am assuming you mean delete the shaders folder?  I no longer have it installed on the new Ssd since it would not work.  I am waiting on a reply from Lockheed Martin to see what the deal is.
Re: Ssd Clone
« Reply #33 on: August 20, 2015, 10:35:44 PM »
Well, actually I mean empty the files out of it, leaving the empty folder intact.  Mine is on my C: drive in
C:\Users\Jeff\AppData\Local\Lockheed Martin\Prepar3D v2\Shaders
And I have a macro that opens that folder and marks all files, which I then delete (permanently, not recycle bin).  It helps sometimes to create fresh ones.
You no longer have a shader cache?  How does that work? ???  You disabled it somehow?  How do you know it was not working?  Isn't it an automatic thing, and is required?
« Last Edit: August 20, 2015, 10:46:55 PM by jeff3163 »
BamaKevin
Re: Ssd Clone
« Reply #34 on: August 21, 2015, 05:11:01 PM »
Ok was finally able to migrate P3D over using Acronis.  This has been a huge headache but its finally over.  Thanks everyone for your input!
Re: Ssd Clone
« Reply #35 on: August 21, 2015, 06:38:24 PM »
Glad you solved the problem.
Re: Ssd Clone
« Reply #36 on: August 22, 2015, 02:47:41 AM »
Hi
have you take the P3D.exe launcher in root folder P3D .v2 to exécute program. ? in the new SSD ..
Re: Ssd Clone
« Reply #37 on: August 22, 2015, 08:41:55 AM »
What I don't understand is that if you made an exact 1:1 copy from the original SSD to the new one and swapped drive letters, then what was the problem? Something had to have gone wrong in your copy/paste, drag n' drop process that dropped, corrupted or missed a file.
Re: Ssd Clone
« Reply #38 on: August 22, 2015, 12:03:33 PM »
You are Right
