Author Topic: Scenery Library Error  (Read 4105 times)
BamaKevin
« on: August 15, 2015, 09:39:07 PM »
Keep getting this Error
Re: Scenery Library Error
« Reply #1 on: August 15, 2015, 10:41:50 PM »
That happens when you delete a scenery file from your computer before deactivating it in the scenery library.  I could barely make out the error message in the picture.  I may be guessing wrong, about what I think the error is saying.  Have you removed any scenery files from your hard drive?
BamaKevin
« Reply #2 on: August 16, 2015, 12:35:03 AM »
I got it fixed I reinstalled part II and III and it now works.  I do have a new problem though.  I can't load a flight at Hollis Harbor after installing the 1.1 patch.
« Reply #3 on: August 16, 2015, 07:39:09 AM »
Good morning BamaKevin,
     In order to help you with your issues, we require more information than you have been providing.  I am not clairvoyant, barely able to read my own mind.  ???  Please give some background as to what you did to arrive at the problem.  Any error messages, CTD, freeze up,  when does the error pop up?  Booting up or in flight?  Any clues would be appreciated.
     Thanks.  ;)
ps- It's also not good policy to raise a second issue in your original thread.  If this problem is not a result of a scenery library error, then we are "off topic" here.  Anyone looking for this issue might not find it.  Whereas someone needing help with a scenery library error would be led up a false path.   ;)
« Last Edit: August 16, 2015, 08:12:16 AM by jeff3163 »
BamaKevin
« Reply #4 on: August 16, 2015, 09:31:54 AM »
Sorry it was late when I posted this.  But I installed Hollis Harbor v1.0 and everything went good loaded it up everything was good.  Went ahead with v1.1 and when I load a flight there crash detected even when loading a flight on active runway.  I did manage to load a flight from ramp 8.  Also noticed no Fedex building.  I have all library's installed.  Checked scenery with tester everything shows up fine. Using P3Dv2
« Reply #5 on: August 16, 2015, 11:54:44 AM »
When you say "crash detected", are you saying your plane is hitting something?  If so, turn off crash detection.  It is the bane of the virtual bush pilot.  We hit stuff sometimes.  Grass and shrubs should not kill us though.  So turn off crash detection please.  If your computer is crashing, that is another matter.  I am reinstalling Hollis v1.1 now (for the experience).  Rod is the creator of the Hollis upgrade scenery location and related software.  He will be able to help you better in technical issues particular to that location.
EDIT:  I see Rod has picked up this conversation on the "Hollis Harbor" thread you also created.
http://forum.mistymoorings.com/index.php?topic=2722.msg22586;boardseen#new
That's great.  Now we're on the same page.  I'll switch my focus there as well, so I don't repeat what has been said already.   ;)
« Last Edit: August 16, 2015, 11:59:33 AM by jeff3163 »
