Author Topic: CSV cabins file  (Read 4200 times)
abrussell
CSV cabins file
« on: March 11, 2015, 03:28:14 PM »
New here at RTMM, so apologies if this has been asked and answered.  There is a column on the page with #'s such as 337.82 etc. Can someone enlighten me as to what they are.
Tks
Bruce
Re: CSV cabins file
« Reply #1 on: March 11, 2015, 03:57:45 PM »
Hey Bruce ...
If you mean a number like this:    N58 10.56 / W134 33.75 - 024*
There are two such columns. The first column locates the structure exactly. That is Latitude, Longitude and Altitude.
The second column is the "mooring point" or "starting Point".  That is the latitude and longitude and MAGNETIC HEADING you use to put yourself in a start position at that location.
You would normally be using the second column.  Lets say you wanted to start at Admiralty Cove Cabin
Look at the second column and you will see:    N58 10.56 / W134 33.75 - 024*
The first set N58 10.56 is the latitude
The second set W132 33.75 is the longitude
The third number 024 is the Magnetic heading.
To place yourself exactly at the starting point, you bring up "MAP" in you sim.  Once it comes up, put the Latitude, Longitude and Heading into the table. Always set the altitude to ZERO and the Speed to ZERO.
When you click OK, you will find yourself at the dock at the Admiralty Cove Cabin.
Let me know if this helps.
« Last Edit: March 11, 2015, 04:04:59 PM by Doug »
abrussell
Re: CSV cabins file
« Reply #2 on: March 11, 2015, 07:15:28 PM »
Last column on the right on the attached
Bruce
  • Troubleshooting & Help
Re: CSV cabins file
« Reply #3 on: March 11, 2015, 07:53:17 PM »
G'day Bruce,
     Those are "heading" numbers.  It's the direction you're facing when placed at the corresponding coordinates.  You put the numbers into the heading box on the map page.  ;)
Location East Florence Cabin 57.80743 -134.58851 109 337.03
Location Hasselborg Creek Cabin 57.657736 -134.253319 249 337.08
Location Jim's Lake Cabin 57.582295 -134.272003 214 337.11
Location Big Shaheen Cabin 57.701437 -134.270979 247 337.06
Location Church Bight Cabin 57.426138 -133.926947 4 337.16
« Last Edit: March 11, 2015, 09:03:25 PM by jeff3163 »
Re: CSV cabins file
« Reply #4 on: March 11, 2015, 08:42:22 PM »
Jeff is correct. What are you trying to do with it Bruce? Wondering how to use the csv file or something?  We can see what it is, but if we know what you want to do with it, we can help you.  The cabins csv file is what you "import" into Plan-G ... and that puts the waypoints for you in plan-G.  Again, i'm guessing. Let us know what you are trying to do, we'll help you get there.
abrussell
Re: CSV cabins file
« Reply #5 on: March 12, 2015, 01:52:07 PM »
Just curious. Tks for the replies.
Bruce
