Author Topic: P3D2.5 WAKE Up like DX10 FSX  (Read 8584 times)
« on: March 01, 2015, 09:20:23 AM »
Hi all some boats another time there is a problem with wake like FSX DX10 in P3D2.5
Henrik work on it :  http://www.pilote-virtuel.com/viewtopic.php?pid=722663#p722663 poste #940
Re: P3D2.5 WAKE Up like DX10 FSX
« Reply #1 on: March 01, 2015, 12:59:55 PM »
Yes, I have this issue also.  Some are correct, some are vertical.  I wonder if the "wake fix" was simply overwritten by the upgrade?  Maybe re-applying it will fix things.   :-\
« Last Edit: March 01, 2015, 01:14:06 PM by jeff3163 »
pringlere
« Reply #2 on: March 01, 2015, 01:47:59 PM »
Here is the fix below is the fx_wake_coastguard.fx effect file used by the RTMM AI Shipping. The lines to delete are bolded. You can edit the fx file with notepad.  Insure you don't save it as a txt file.
[Library Effect]
 Lifetime=5
 Version=2.00
 Radius=-1
 Priority=0
[Properties]
 Cockpit=1
 VirtualCockpit=1
 Spot=1
 Tower=1
 Map=1
[Emitter.0]
 Lifetime=0.00, 0.00
 Delay=0.00, 0.00
 Bounce=0.00
 Rate=1.00, 1.00
 X Emitter Velocity=0.00, 0.00
 Y Emitter Velocity=0.00, 0.00
 Z Emitter Velocity=0.00, 0.00
 Drag=0.00, 0.00
 X Particle Velocity=0.00, 0.00
 Y Particle Velocity=0.00, 0.00
 Z Particle Velocity=0.00, 0.00
 X Offset=0.00, 0.00
 Y Offset=0.00, 0.00
 Z Offset=0.00, 0.00
[Particle.0]
 Lifetime=44.0, 44.0
 Type=21
 X Scale=12.0, 12.0
 Y Scale=12.0, 12.0
 Z Scale=0.00, 0.00
 X Scale Rate=0.10, 0.10
 Y Scale Rate=0.10, 0.10
 Z Scale Rate=0.00, 0.00
 Drag=0.00, 0.00
 Color Rate=0.11, 0.11
 Fade In=0.10, 0.10
 Fade Out=0.60, 0.60
 Ground Normal=1
 Shade=1
 Face=1, 0, 1
[ParticleAttributes.0]
 Blend Mode=1
 Bounce=0.00
 Color Start=168, 222, 221, 180
 Color End=255, 255, 255, 0
 Jitter Distance=0.02
 Jitter Time=1.00
TempK=109.00 <———–Delete
 TempRate=0.01 <———–Delete
 uv1=0.00, 0.00
 uv2=1.00, 1.00
 X Scale Goal=64.00
 Y Scale Goal=64.00
 Z Scale Goal=0.00
 Extrude Length=30.00
 Extrude Pitch Max=90.00
 Extrude Heading Max=10.00
[Emitter.1]
 Lifetime=0.00, 0.00
 Delay=0.10, 0.10
 Bounce=0.00
 Rate=1.00, 1.00
 Drag=0.00, 0.00
 X Offset=0.00, 0.00
 Y Offset=0.00, 0.00
 Z Offset=0.00, 0.00
[Particle.1]
 Lifetime=42.0, 42.0
 Type=21
 X Scale=17.0, 17.0
 Y Scale=17.0, 17.0
 Z Scale=0.00, 0.00
 Drag=0.00, 0.00
 Color Rate=0.00, 0.00
 Fade In=0.05, 0.05
 Fade Out=0.70, 0.70
 Ground Normal=1
 Shade=1
 Face=1, 0, 1
[ParticleAttributes.1]
 Blend Mode=1
 Bounce=0.00
 Color Start=255, 255, 255, 200
 Jitter Time=1.00
 uv1=0.00, 0.00
 uv2=1.00, 1.00
 X Scale Goal=60.00
 Y Scale Goal=60.00
 Z Scale Goal=0.00
 Extrude Length=70.00
 Extrude Pitch Max=70.00
[Emitter.2]
 Lifetime=0.00, 0.00
 Delay=0.10, 0.10
 Bounce=0.00
 Rate=1.00, 1.00
 Drag=0.00, 0.00
 X Offset=0.00, 0.00
 Y Offset=0.00, 0.00
 Z Offset=0.00, 0.00
[Particle.2]
 Lifetime=22.0, 22.0
 Type=21
 X Scale=15.0, 15.0
 Y Scale=15.0, 15.0
 Z Scale=0.00, 0.00
 Drag=0.00, 0.00
 Fade In=0.05, 0.05
 Fade Out=0.70, 0.70
 Ground Normal=1
 Shade=1
 Face=1, 0, 1
[ParticleAttributes.2]
 Blend Mode=1
 Bounce=0.00
 Jitter Time=1.00
 uv1=0.00, 0.00
 uv2=1.00, 1.00
 X Scale Goal=60.00
 Y Scale Goal=60.00
 Z Scale Goal=0.00
 Extrude Length=50.00
Thanks,
Rob
« Last Edit: March 01, 2015, 03:08:46 PM by pringlere »
« Reply #3 on: March 01, 2015, 07:06:01 PM »
In the poste P.V. com, Henrik made correctif for 2 boats, crossing  Gibraltar  and i TEST here boats Test .... it's OK
in few all w'll be corrected .
see you next
« Reply #4 on: March 02, 2015, 06:15:10 PM »
Made IN :  by HENRIK
Link to dowload correct wake in 2.5
https://www.dropbox.com/sh/qzf7fbi31y9r … vutka?dl=0
« Last Edit: March 04, 2015, 04:54:07 AM by NeptuneP2V7 »
« Reply #5 on: March 04, 2015, 08:15:25 AM »
This link does not work for me.   :'(
« Reply #6 on: March 04, 2015, 09:37:37 AM »
I agree, the link is broken.  :-\
  • Guest
« Reply #7 on: March 04, 2015, 02:39:12 PM »
The fix is on AVSIM and Flight Sim
av8erjm
« Reply #9 on: March 06, 2015, 04:58:07 AM »
Hello,
Yes henrik, withdrew its Dropbox because it has download on sites : Avsim, flightsim ...  ;)
but you know remedy  ;D
