Author Topic: Hospitals  (Read 221940 times)
Re: Hospitals
« Reply #60 on: March 14, 2015, 06:34:56 PM »
Hi Steve,
It is okay to build over another scenery file that is enabled, if that is what you are asking, as long as that other scenery is always lower on the Scenery Library priority list for the scenery you are creating.  That is always the case with ORBX since RTMM scenery is above ORBX.  Unlikely that it will come back.  Assuming other parts of the scenery were saved, it is more likely that you did not save it to a file properly or saved it to a file that was not enabled....though usually IS gives you a warning on that.  In any case, try adding the building again to your scenery file, makes sure you save it properly and then reload FSX to see if it is still there.  If not, could be another problem.    There should be no need for an exclusion unless you want to removed an object from another scenery that is in your way.
Re: Hospitals
« Reply #61 on: March 15, 2015, 04:33:24 PM »
Taking it "up" a notch!
We are creating a web page for the RTMM Medical Facilities.  The page is "under construction" at this point, and very "basic" in structure. But if people are interested in watching the progress of this project, they can watch the construction process on the "RTMM Medical facilities Beta Page" (You can also get to the page from the bottom of the Scenery Page, in the "beta test area" below "Z"). There will not be any hot links in this new page until we are finished.  Suggestions are welcome as we build this.  We are building this for YOU, so your input is most welcome.
« Last Edit: March 15, 2015, 04:40:14 PM by Doug »
sddinnh
Re: Hospitals
« Reply #62 on: March 15, 2015, 06:30:20 PM »
Nice job Doug  ;D  I like it.
Trex3D
Re: Hospitals
« Reply #63 on: March 15, 2015, 07:15:52 PM »
Magnifico Doug and RTMM! Since the topic here is about about medical emergency airlifts/medevacs, here's a short 1.5 mins. trailer video on HEMS featuring the BK-117 air ambulance in Germany... and a longer 7.5 mins. accident rescue documentary with Mercy Air B222 on the second video for those who want to take a coffee break from flying...  ;D
https://youtu.be/ml7jWXfmQ0k
https://youtu.be/BcXxvrWOsgc
« Last Edit: March 16, 2015, 05:10:27 PM by Trex3D »
Re: Hospitals
« Reply #64 on: March 17, 2015, 08:24:59 PM »
Thank you Trex, very interesting.  The new web page continues to "build" ... added some more today. Steve Downing is doing most of the work since I'm "IS3-Challenged" (P3D2.5).  The first phase of this project is to get the major medical centers in place and many "remote" facilities (smaller ones out at SPB's, etc). Once we have these in place, we will begin adding "Medical Dispatches" ... putting a "problem" out in the scenery, giving you a waypoint to the problem, then you fly to it, and fly back to the appropriate medical facility.  Rod has given us an example one we are testing and it is working perfectly. (Typical Rod!)
If you look at the web page, (HERE) you will see each facility has a "waypoint" ... these are put in much as a pilot would put in the critical waypoints for him to do his job ... we will "preload" your gps with all of the medical facilities in a single download ... all the waypoints will be there. You simply bring up your GPS and do a "direct to" to the waypoint.
We have relied mostly on Plan-G flight plans for our low and slow and around the mountains routing. This will be different and more difficult. The GPS will give you a "straight line" to the target. It will be up to you to get there safely. It is a different kind of flying and actually more realistic for bush flying.  This is going to be a terrific program for the rotorheads among us ... but we are not leaving out the fixed wing people. You will see that most of the hospitals have a nearby "medical dock" ... usually water. We will place some emergencies where an amphibian could land and take off, then land near the hospital.  We'll keep you posted on progress. Below is a screenshot of the Skagway Medical Dock. The copters would land at the hospital, the float planes at this facility ... and you can see the ambulance is waiting ...
DOug
« Last Edit: March 17, 2015, 08:27:44 PM by Doug »
Trex3D
Re: Hospitals
« Reply #65 on: March 17, 2015, 09:36:20 PM »
Thanks a lot for the heads up Doug, I was just sharing scenarios as depicted on those overview videos on what HEMS ops do for those wondering what it's like in the RW... Of course, it's everyone's sacred duty to extend help those in life or limb threatening emergencies and airlift them ASAP to the nearest medical or trauma facility either through fixed wing, helo or whatever transport is available. Also, thanks for letting us RTMM'ers play and do practice runs as heroes.. at least in our virtual world ;-) Kudos also to Steve D. and other talented contributors for this wonderful project.. :-*
P.S. That Beaver is precariously docked too close to the HEMS pad unless the operator's insurance will fully cover possible damages caused by rotor clipping as well as lawsuit from the patient and/or family if another disaster happens.. but a 500 ft. radial clearance from the TOLF will be fine with the FAA  ;D
« Last Edit: March 19, 2015, 08:54:36 PM by Trex3D »
Re: Hospitals
« Reply #66 on: March 18, 2015, 07:08:26 AM »
 :) I had just made a run from Haines medical dock and was quick-docking to get the "patient" out.  By the way, some helos will use that dock instead if the hospital...look at the enlarged pic for Skagway hospital...a tight landing in high winds or poor visibility.
« Last Edit: March 18, 2015, 08:46:33 AM by Doug »
Trex3D
Re: Hospitals
« Reply #67 on: March 18, 2015, 10:01:44 PM »
Sounds challenging...  :o ;D :P
Re: Hospitals
« Reply #68 on: March 22, 2015, 02:25:05 PM »
The Medical Facilities page is growing and coming together nicely.  You can watch the progress on it here:
http://return.mistymoorings.com/medical_facilities/
I also put a temporary "button" for it on Misty's Place, and there is a link to it in the "beta section" at the bottom of the scenery page.
Feel free to comment on this thread as to what you are seeing.
Re: Hospitals
« Reply #69 on: April 04, 2015, 12:05:40 PM »
RTMM Medical Facilities Update
Several new medical centers have been added (you can see the complete list HERE). We now have most of the urban centers listed, that was the first step of the project. Next, we will be offering a "temporary" medical facilities library, that will hold some special new Objects Steve Weinkamer has created for us. We then have to run a Quality Control on this base package (Spud), then we will turn loose the RTMM Medical Facilities.zip for you.
Soon the fun will begin. We will be adding "medical dispatches" (E-Tickets).  You will download the dispatch and in the zip folder you will find (1) a map, (2) mission instructions, (3) and (4) a little scenery folder that you will put into your scenery library (instructions for placement will be included).  We will begin adding these once we have the basic project established (temp library, major medical facilities, new web page).
We will be making these for helicopters and fixed wing aircraft. You will see the three tables on the new web page for these. All naming of these will start with an "E".
You are welcome to add to this discussion with ideas or questions.
Re: Hospitals
« Reply #70 on: April 04, 2015, 08:16:02 PM »
Fun's A'comin' ....
Re: Hospitals
« Reply #71 on: April 05, 2015, 04:16:54 PM »
And here's what Spud found at the "emergency" site:
