Author Topic: Angels 10 No Problems  (Read 3683 times)
« on: September 09, 2014, 05:51:54 PM »
Finally, I think I have P3D 2.3 running at max on my system. I always felt it was on the "edge" and I was getting ctd often.  I was seeing stutters and I had the sliders pulled back. The key was in changing a single line in the cloud.fx file.
From: GetScreenQuadPositions( quad, width, height );
To:  : GetScreenQuadPositions( quad, width*0.5, height*0.5 );
The result, for my system was astounding.  Increased frame rates, no stuttering, no crashes, beautiful cloud formations (using OPUS).  I'm flying cross country at 10,000 feet to see how long I can go without a crash to desktop ... not even close, my CPU mem is around 35%, I was running in the high 40's and crashing in the 50's. So I think this was the solution to my problem. I've kicked up my sliders and graphics ... wow.
Re: Angels 10 No Problems
« Reply #1 on: September 09, 2014, 06:03:05 PM »
Nice!
« Reply #2 on: September 09, 2014, 07:49:12 PM »
for a week i try it
but i find for my config an other value set
see that and try it  GetScreenQuadPositions( quad, width*1, height*0.5 )
also in this pic AVSIM http://forum.avsim.net/topic/451123-brighter-hdr-tweak/
i make a VID with the tweak
i prepare an other with the 2 VID in one
56Csw
but in second part i miss spécial effects  :P
see you next
« Reply #3 on: September 11, 2014, 12:43:16 PM »
Ok
hi guys
i do this Vid
56Csw
for the different rendering HDR and tweak : At line 166 you will find '  //avgLuminance *= 0.85f; ' which is commented out by the two slashes.
remove the two slashes ie:  ' avgLuminance *= 0.85f; ' and save.
See you next
