Author Topic: Adaptive VSync  (Read 5225 times)
  • Guest
Adaptive VSync
« on: June 16, 2014, 07:24:39 PM »
This will work on NVIDIA series 600 and above..
http://www.prepar3d.com/forum-5/?mingleforumaction=viewtopic&t=7211
Re: Adaptive VSync
« Reply #1 on: June 18, 2014, 03:19:14 PM »
hi,
 there is no need to tweaked NVIDIA inspector is no longer updated since 2013 we are mid-2014 we stayed in 1.9.7.2
So just tweaked by NVIDIA Control Panel, to manage 3D Settings ONLY
Re: Adaptive VSync
« Reply #2 on: June 18, 2014, 07:52:23 PM »
That is a good point.  However, I am used to inspector so I use it.  The NVidia control panel is functional except that it does not show the detail settings (drop downs) you currently have set....e.g. antialiasing setting.   Inspector shows that nicely.  Maybe there is a NVidia report/display that I don't know about.....
« Last Edit: June 18, 2014, 07:58:19 PM by stiletto2 »
Re: Adaptive VSync
« Reply #3 on: June 20, 2014, 06:15:29 AM »
Hi stiletto2
the best way founded,  with Nvidia control panel  and unactive NVInspector FSX
for Graphic cards series 7xx, 6xx, 5xx .
try it in the same airport same MTO same situation, with and whitout and tell me if you have a new best refinement and  nicety display
my control panel, is french but you find the same in english  ;)
Nvidia driver since 2013 have evolved series xxxx
You have Synchronisation vertical (vertical sync ) Adaptive 1/2 frequency display
and in
 [GRAPHICS]
// + this  line.
ForceWindowedVSync=1
so if you have prob to translate french tweak Nvidia, i can help you
« Last Edit: June 20, 2014, 06:30:19 AM by NeptuneP2V7 »
Re: Adaptive VSync
« Reply #4 on: June 20, 2014, 02:58:46 PM »
Hi Patrick,
Upon further research I see now that Inspector is able to set a lot more settings for the NVidia video driver than are available in the generic NVidia control panel.  For example, for the Anticrenelage-reglage setting I use 8xSQ which is a custom combined setting that only shows up in the NVidia control panel as a custom choice has been made.
Best I can tell, there is not way to set the NVidia video driver to 8xSQ without Inspector.
Re: Adaptive VSync
« Reply #5 on: June 20, 2014, 10:31:05 PM »
YEP  stiletto2
 NVIDIA and STEVE Parson DX10 SF  are the Same value
 there is only 16xQ CSAA   ;)
have  a good day
