These sounds are placed in different areas of the scenery. The sounds in Chester's start at dusk and go into the night. The sounds are also directional. If one is in slew mode, the sound will be muted. If one hears a strange sound, you can listen to the *.wav files with windows media player. The Winamp player
may not play certain wav files. If you unzip the sound file to a temporary folder, and you double click on
a wav file, Windows Media Player should play the sounds in that file. I am having second thoughts about adding sounds since each person has a different computer configuration. What works and sounds good to me may not work for someone else.
