I downloaded all of the sound enhancements earlier and simply installed them as directed.
As time went by I was wondering where I was supposed to be at Misty's to hear these sounds.
I did not check back on the forums as I (usually) am the problem. I checked and checked my install with no joy.
I then decided to try the sound files. Yep, they work
I then decided to check the fx files.
They seemed to be OK so I stuck with the Misty's Hangar sound for my studies.
I messed around more than I would like to admit all day and eventually did get the effect to work as a new bgl at a different airport. I even managed to get IMM to use it and when the mission started I heard the sounds of the effect.
I then got the bgl2xml tool working and stared at the files for a while.
A couple of things caught my eye;
a) The apostrophe's are nasty things and confuse me so I removed them from the fx, xml and related files.
b) The effect file refeerence that I found in the bgl was not the same as that which I downloaded; for example,
an fx file call looks like fx_misty'sSomethingSomething but the actual fx file was named like fx_mistys_something_something. So I changed the xml to reflect the actual name of the fx file (with no 's).
I then recompiled the bgl's from these new xml files and placed them in a new scenery folder up higher than where misty's other scenery files are and reloaded FSX. (I wanted to be very safe at this point)
Much to my relief Misty's is now full of sounds.
If my issue is found to be an issue for any others I can make my files available for review.
P.S. I am still looking for the
party.wav file. I do not seem to have it.
______________________________________________________________
Example of what I found for the campfire effect:
<Effect
effectName="fx_MistyCabinFire"/>
My new version:
<Effect
effectName="fx_misty_cabin_fire"/>
