Author Topic: NOTAMs and NEWs Thread  (Read 3503 times)
Re: NOTAMs and NEWs Thread
« Reply #270 on: January 05, 2019, 01:54:57 PM »
Misty's Place 2019 ... Refreshed and with Season Switcher
Misty's Place has been totally refreshed. A better airstrip, many options for night lighting, Season Switcher capable, highway connection to PAKT (Payware and Standard options).  This was one of Brad's first scenery locations for RTMM.  Many years later, he has made it even better. All the information you need is in the PDF readme and in the installation instructions that you can view by clicking the buttons at the bottom of the location segment on the Scenery Page.
This is out "home away from home" and it has never looked better! Look under "M" on the Scenery Page for the download.
« Last Edit: January 05, 2019, 01:59:14 PM by Doug »
« Reply #271 on: January 14, 2019, 04:53:32 PM »
C.I.R.P. (GLACIERS!) ... has been TOTALLY Refreshed!
The entire CIRP program has been revamped, new downloads and a new dedicated CIRP page. All of the ice stations (10) are now in the SAME download zip file ... one download, all 10 stations and the ndb's too.  If you look on the Scenery Page under "C" you will see all the CIRP entries, the ice stations zip, plus all of the other CIRP addons associated with the program. Everything can be downloaded in about 3 minutes now.
NOTAM: You should DELETE all of your CIRP sceneries from your Sim's Scenery Library, then add these refreshed files.  DO NOT overwrite!
The CIRP Scenery Page has been totally revamped.  The only thing we are really missing is the hovercraft (we are looking for a replacement). But in the meantime, the CIRP Stalwart is one heck of a land vehicle.  You can download a "tricked out" Stalwart from the Land Operations table.  Following the glacier dispatches, you can drive the vehicle safely out on the ice and literally cover MILES and MILES of terrain. The "Tricked out" version is set up with 3D REDUX lights if you have the program and a special modified "Ground Handling" system that give you speed control for the vehicle.  The engine is souped and can send the Stalwart up very steep inclines.
For the air operations there are dispatches that will take you on various supply runs out to the 10 ice stations. All of them are equipped with an NDB so you can tune in your target station on the vehicle's ADF and find the location. This can give you some spectacular flying ... 6000 feet and higher. Weather is always a factor .. and when it is "clear" ... the view is spectacular showing you the fastness of the glacier system above the beautiful Misty Fjords.
There is an "introductory" tour on the CIRP page so you can take a tour (once you've loaded up CIRP) that will take you from PAKT to Summit Ice Station. A great way to see the transition from Fjords to Glaciers, all autopilot guided (except for altitude) so you can enjoy the tour.
All of the location downloads are done from the Scenery Page under "C". And all the information and dispatches are on the dedicated CIRP page
« Last Edit: January 14, 2019, 04:57:05 PM by Doug »
« Reply #272 on: January 30, 2019, 08:33:11 PM »
Aerosoft DHC6-300 Twin Otter - Misty Repaints by Thomas Menzel
Thomas has given us a beautiful Misty Moorings Repaint of the Aerosoft DHC6-300 for the Amphibian, Ski Wheel and Tundra models. You can find these on the Enhancements page. Go to Repaints/Fixed Wing and look at the bottom of the table. Click on the picture and the zip with all three textures and readme instructions will download for you.
Thank you Thomas!
« Reply #273 on: February 02, 2019, 01:39:24 PM »
Lockheed Martin P3DV4.4 C-130J - BWEP Repaint by Thomas Menzel
Thomas has given us a beautiful BWEP Repaint of the Lockheed Martin P3DV4.4 Default C-130J Hercules Aircraft) (Repaint is also compatible with Captain Sim's C-130
X-perience Base Pack [FSX], You can find this on the BWEP page. Go to Repaints/Fixed Wing and look at the bottom of the table item 19.
Click on the picture and the zip with the texture folder and readme instructions will download for you.
Thank you Thomas!
« Reply #274 on: February 04, 2019, 10:38:27 AM »
Dean River - Re-Refreshed
We found an error in the winter setting for Dean River. That has now been corrected. There is a new file up on the server. Always look at the DATE to make sure you have the latest of any of these.
« Reply #275 on: February 06, 2019, 02:16:10 PM »
Hidden Inlet Lake Cabin and Hidden Inlet Retreat - Re-Refreshed
We had a "tree color" error in these two. That is now fixed. They are still "Version 2.0" but you'll notice the date is for 02.06.2019.  These are now season switchers and they need to be re-downloaded for you to have the latest.
These two are worth a visit, go for the cabin first (it is "on the way") then head for the retreat. You should use an amphibian, landing on water at the cabin, then on the landing strip at the retreat. All lit up for dusk operations too.
« Reply #276 on: February 07, 2019, 07:59:19 AM »
Season Switcher added to: Fortaleza Ridge Cabin and Hang em High (Re-Refreshed)
ALSO: Hang 'em High also has been significantly altered at the "upper lodge". The boulders making the cliff there tend to "shift" ... making the launch runway unusable. That is now fixed.
« Reply #277 on: February 08, 2019, 05:25:16 PM »
REFRESH 2019 ....
Don't forget to check on the Scenery Page, top table, to get the the latest pdf of the locations that have been refreshed. We are putting up a couple or more a day ... busy busy.
One heads up ... on Hang 'em High ... I did a RE-refresh on that one. There was a problem with the ramp structure (Version is now 2.1 and date is 02.08.2019).  The launch ramp was completely rebuilt. Then a season switcher was put in. Thanks to a lot of support from various members of the team, we cobbled together a great paraglider by altering some of the graphics so it would work with P3D V4.  If you want an interesting experience, download Hang em High and download the powered paraglider from there too.
Today alone we put up Hang 'em High, Lucky Lindy's, Nisga's Glacial Lake and Prayer Lake Cabin.  All of these are now done with Rod's Season Switcher and make for some great locations to visit.
Be sure to watch for the Refresh 2019 logo on the scenery page to update your favorite location.
« Reply #278 on: February 13, 2019, 03:21:17 PM »
New RTMM Library Part IV ready for Download
NEW !! RTMM Library Part IV (02.11.2019) is ready for download. This package contains various fixes and improvements to a number of RTMM object libraries and RTMM scenery files. It is EXTREMELY important to carefully read the documentation in each folder in order to make the changes and additions to your RTMM installation as easy and efficient as possible. It is imperative that ALL of the files in this package are installed, without skipping or ignoring any of them. Failure to do so can, and will, make it difficult to RTMM staff to debug future issues users may have with their scenery.
Few can imagine the hours that goes into a project like this, but please, take a moment and give Steve a thank you for a tremendous job.  Watch for his posting explaining all of this in detail on the forum.
You will find the download on the Object Library Page.
« Reply #279 on: February 17, 2019, 09:04:07 PM »
CIRP 350 Repaint by Klaus Tröppner
Here is a beautiful CIRP repaint by Klaus for the Aerospatiale AS350 Astar helicopter from Nemeth Designs. This one is a beautiful bright addition to the white ice of CIRP! You can find it on the CIRP Web Page under Air Operations ... click on the picture at that location to download the reapaint.
